Is it possible to g...
[Closed] Is it possible to glue the soles back on cycling shoes?
[#6324347]
Well, obviously it's possible, but will they stay on long term?
I pulled the soles off my Sidi shoes.
I've glued the soles back on trainers with hot melt glue before, although they've always needed doing again after a few months.
Is there a glue I could buy, or a place I could send them to to be glued for a permanent repair?
I guess a high street cobbler could do it, but is their glue strong enough? Normal shoes don't have to stand having the sole actually pulled away from the upper like a cycling shoe.
Posted : 08/07/2014 12:05 pm
I have had good results gluing the sole back on my ageing
Wish they still made them ..
Using [url= http://www.toolstation.com/shop/p58347?utm_source=feed&utm_medium=googleshopping&utm_campaign=googleshopping&mkwid=i5HI0W4o&pcrid=26799045143&gclid=CL-Zg9DKtb8CFeyWtAod7CAAhg ]This serious glue[/url]
Posted : 08/07/2014 12:14 pm
 D0NK
cobbler I took mine to said probably not as he couldn't get them on his last to apply some real pressure, he did attempt it and didn't charge me for the slightly shoddy looking results, haven't actually tried them out yet, fear of soles parting company in the middle of nowhere.
Posted : 08/07/2014 12:17 pm
You could try Sikaflex EBT (Screwfix amongst others)
Seems to bond anything to everything and is permanently flexible.
If you do, i would say at least 3 days to achieve full bond strength.
Posted : 08/07/2014 12:39 pm
Couple of short screws through from the inside.
Posted : 08/07/2014 12:40 pm
 nach
Shoe Goo or Barge Cement.
Also: [url= http://thistothat.com ]http://thistothat.com[/url]
Posted : 08/07/2014 1:01 pm
They do look very gluable I would atleast be trying it.
Posted : 08/07/2014 1:04 pm
 tsd
I glued my Diadora road shoe soles back on. Lasted for a couple of years.
Posted : 08/07/2014 2:30 pm
Not with vegan glue.
Posted : 08/07/2014 2:41 pm
Used to be a regular problem with Sidis, tried a few different glues with no real success, so took them to a cobbler who glued and stapled them on.
Posted : 08/07/2014 9:37 pm
i've used silicone sealant with a bit of wood in the shoe and a couple of clamps leave for a couple of weeks lasted over a year so far
Posted : 08/07/2014 9:46 pm
ensure all muck and mud is removed with a soapy water wash and rinse then a brush with a wire brus, then apply a coat of evo stick contact adhesive to each surface allow to dry and then squeeze together and leave in a warm place for a day.
contact adhesive sticks to itseelf so some cling film between shoe and sole will allow a bit of manouvreability before you touch both parts togeter
Posted : 08/07/2014 9:50 pm
Shoo gue has worked for me!
Posted : 08/07/2014 9:52 pm
Thanks for the suggestions.
Sikaflex sounds a good idea as we use that at work for sticking bits of bus together. I don't know why I didn't think of that.
I'll probably pull the soles off completely so I can clean it all properly, then carve a block of wood to make an improvised last so I can clamp them together.
Posted : 09/07/2014 9:01 am
