Is it new tyre time...
[Closed] Is it new tyre time?
[#10791671]
After my 50 mile, 10,000ft of descending weekend, I think it may be time for a new rear tyre. What say, STW?
[url= https://live.staticflickr.com/65535/48660172311_ec6aac2eba_b.jp g" target="_blank">https://live.staticflickr.com/65535/48660172311_ec6aac2eba_b.jp g"/> [/img][/url]
[url= https://live.staticflickr.com/65535/48660318952_e9f831e5df_b.jp g" target="_blank">https://live.staticflickr.com/65535/48660318952_e9f831e5df_b.jp g"/> [/img][/url]
Also, I think I may have overheated my rear Deore 2 pot brake at BPW...
[url= https://live.staticflickr.com/65535/48659820863_c0043af88d_b.jp g" target="_blank">https://live.staticflickr.com/65535/48659820863_c0043af88d_b.jp g"/> [/img][/url]
Maxxis Aggressor 2.5WT rear (to match the Minion DHF 2.5WT front which is practically new), or a set of Vittoria Martellos?
Posted : 01/09/2019 7:23 pm
I’d buy a fresh one now but only put it on when the weather turns.
Posted : 01/09/2019 7:31 pm
See that's what I was thinking, it's basically a semi-slick at the moment.
Posted : 01/09/2019 7:32 pm
you can tell you've been braking hard in terror and not leaning it into the corners. loads of life left.
#inbeforegeex
Posted : 01/09/2019 7:35 pm
Geex would be ashamed to have that much tread on his front tyre nevermind his back tyre.
Posted : 01/09/2019 8:35 pm
Looks like you skidded the shit out of it!
Posted : 01/09/2019 9:36 pm
It is over a year old, 1000 miles too - was the original front tyre on my bike, swapped it to the rear when I fitted the 2.5WT minion up front.
Posted : 01/09/2019 9:38 pm
The nobbles don't really do anything, they're a marketing gimmick. Basically a fashion accessory.
Posted : 01/09/2019 9:40 pm
re brake overheat - quick rub down of rotor & pads with sandpaper should remove most of the glazing.
couldnt find much in the background to critique sadly  🙂
Posted : 01/09/2019 9:52 pm
I’d just stick it on the front.
Posted : 01/09/2019 10:03 pm
Need to clean out the moss from between the bricks
Edit: keep it for the summer and pretend its a semi slick
Posted : 01/09/2019 10:38 pm
I would keep that on for a while longer... then again, I don't have to contend with English weather all the time.
I don't mind the rear being a bit drifty as long as the side knobs are not ripped. I find the 3c bad for this, especially in the front.
Posted : 01/09/2019 10:49 pm
