Just done some browsing and I think I know, but I thought I'd check.
Brake is a IS caliper Hope (C2) with (I think) a 160 disc
Fork is a post mount Marzocchi MX Pro SL
As I understand it I need to go +20mm on the rotor and fit one of [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=13735 ]these[/url]
Does this sound correct?
Do you have to increase the rotor by 20mm?
CRC say the bracket doesn't fit Marzs but some people say it does...
yup, thats what i used on a fox 36 for a hope IS caliper, adding 20mm to the rotor size in the process. no idea if it works for zokes though.
Fitted one to friends MX comps/C2 with no problem fairly recently. If it's a C2 system you'll have a 165mm disc, and need a 185mm.
cheers
