Internal headsets a...
[Closed] Internal headsets and press fit BBs - why?
 gee
[#2486338]
What exactly was wrong with a normal headset and BB?
About all I can think of is no threads to strip in a BB shell and slightly larger weld area on the top tube/downtube join - although I never had any problems with either of those things...
GB
Posted : 19/02/2011 8:30 pm
 ton
more sales boolox gee.
Posted : 19/02/2011 8:32 pm
 gee
Well that's my take on it too.
Posted : 19/02/2011 8:34 pm
make is scary for people to DIY fit/remove.
actually works very well as a fitting solution - lots of things are press fit in situations were threads would be problematic.
and talking of which - threads can cause lots of problems, including alignment problems. Press fit stuff will be perfectly aligned.
+ once fitted you will be less likely to replace the whole lot and resort to buying overpriced replacement bearings that cost more than a new headset.
Posted : 19/02/2011 8:36 pm
