Has anyone managed to fit an internal dropper on a Scott Spark ?
There is a plastic cover at the bottom of the frame which may allow the hose to come out from if its drilled. But I've not taken it off for a good look.
Just wondered if anyone has already investigated it.
Cheers.
Bump for Monday lunchtime ?
Not a spark but on my genius which I run 1x10 I have drilled out the intrrnsl routing front mech cable stop at the head tube and run fully sealed cable for my DOSS. This exits the frame at the back of the seat tube as its not a 'stealth' post.
I have not checked if hydro hose will fit through the cable stop.
Mmm, I'm 1x11, so I could route the hose internally and have it come out where the front mech cable would normally go. The hose for a Reverb is likely to be a bit bigger than a cable.
But I really wanted to avoid any drilling of the frame (well at least while it has a warranty)
Making a hole in the plastic cover at the base of the BB would be simpler. I will have a look later when I'm home.
