Ive just bought a new frame and it came with an intergrated headset
I dont know much about these?
The top bearing seems to be a tight fit but the bottom bearing is very loose! Is this normal? about 1/2 mm play side to side but does sit flush with machined chamfer in frame....
Also got a new set of rockshox reba dual air forks. One of the stanchions was covered in oil! should i be sending them straight back?
cheers
Posted : 13/01/2010 11:38 pm
They only sit in the frame as opposed to being pressed in.
Sounds OK if it was the wrong type it would either be too big or very sloppy.
What frame?
Posted : 13/01/2010 11:41 pm
Thanks, pinnacle team fs from evans
Posted : 13/01/2010 11:55 pm
Ahh I don't know anything about Pinnacles 😐
Posted : 14/01/2010 12:00 am
