Integrated headset ...
[Closed] Integrated headset fitting - loose?
[#3484514]
Just fitting a headset in a new frame. It's the first time I've had an integrated HS. The bearings just drop into the frame. They arnt loose but no pressing is needed. Is this right?
Posted : 21/12/2011 10:16 pm
are they integrated or semi-intergrated, needing a cup, al la zero stack?
Posted : 21/12/2011 10:28 pm
No cup needed. Direct in frame
Posted : 21/12/2011 10:41 pm
what frame? what headset?
Posted : 21/12/2011 10:45 pm
There are a few different 'standards' for integrated.
41.2mm cane creek,
41.7mm TH shallow,
41.7mm TH deep,
42.05mm Italian,
45mm ICBM (no not the missile).
Are you sure you've got the correct headset?
If you have they just drop in.
(I REALLY need to get out more)..
Posted : 21/12/2011 10:47 pm
Commencal super 4. Ritchy comp HS. Both campy standard.
Posted : 21/12/2011 10:58 pm
Splurge some grease in there and she'll be reet.
Posted : 21/12/2011 11:01 pm
That was my thinking!
Posted : 21/12/2011 11:02 pm
