instagram live has ...
[Closed] instagram live has changed my mind on frame - Help!
[#11879547]
So without naming names, a recent instagram live cock up by the nameless brand has changed my mind on which bike I want to buy.
Was just about to pull the pin on a frame and now I find myself looking for alternatives, which as you are probably all aware is not easy at the moment with the lack of availability.
looking to mind the collective for any options i've missed that are (or are due to be) in stock
requirements:
a long large or XL frame
29" wheels
150-160 rear travel (maybe 140 at a push)
takes a 160 fork
Boost
£1k - 2.5k cost (lower the better)
(basically an enduro bike frame)
current options are:
Bird AM9 (handy as have a new Fox Float X2 in the right size and, Cheap) - Pro's, got first hand experience of the Aeris 145 and quite impressed with it, Cons, not ridden the 29er
Cotic Rocket Max - zero experience of them
Privateer 141 - Pros, Geo i like the look of, Cons, Heavy as a house, been there done that, not sure i want to go back
Privateer 161 - As above, but mooooorrrreee and would have to be full bike to get it in a reasonable time
And that is where I am drawing a blank. Want something before July ideally so happy to wait a little. just wondering if there is anything out there i've missed, keep feeling like there is.
Will sit back and wait for the "just buy the AM9" comments...
cheers
Posted : 12/05/2021 7:02 pm
You can probably buy the bird without a shock, use the (excellent) shock you have, and there's nothing else in stock
Buy the Bird, and tell us about the IG cockup.
Posted : 12/05/2021 7:07 pm
Am9 owner here, it just works. Three years old next month, no issues.
Posted : 12/05/2021 7:09 pm
May delivery bikes are due in very soon, just saying...
Posted : 12/05/2021 7:14 pm
Whisper it, if only to stop us from recommending something you now won’t buy.
Posted : 12/05/2021 7:18 pm
As per the Singletrack tradition of "recommend what you have" I would seriously recommend the RocketMax. Just got it around a month ago and it's such an amazing bike. Descends better, jumps better, climbs better than the bike it's replacing, I'm able to keep up with mates I never thought I would be able to now, so it's objectively quicker if that's what you're in to.
Won't fit the 230x65 I assume you have (out by 2.5mm on the stroke volume), but I'm really impressed by the DB Kitsuma, you'd get a fair chunk for the shock selling it on I'm sure?
They have stock of L and XL in both colours right now so you would def have it by July. I've bought a rocketmax full bike and Bfe frame off them recently and they've been such lovely people to deal with that in the unlikely event something did go wrong they'd sort you out quickly no bother.
Also you mentioned the weight of the privateer as a con - rocketmax was the lightest of the test bikes in bikeradars bike of the year test as well
Posted : 12/05/2021 7:22 pm
I'm not naming the brand as I could have misinterpreted it.
Essentially they went live and the feed i logged into heard them mention not to focus on the wear on the shock or where the linkage has worn the frame. then it cut off.
So, on that basis i've read into it that the frame is either very flexible and causing wear were it shouldn't or it is entirely possible they have absolutely hammered their bikes and wanted to show them off in the best light by not focussing too closely on said worn areas.
Either way, i'm out.
I think Privateer is out on the weight basis.
so that does just leave the AM9 and the Cotic.
My shock is a 230 x 57.5 and only 2 rides old. i'd need to get the stroke adjusted to fit either frame, but it will fit both of them. Just the small matter of £1k difference in price, which makes the AM9 really appealing, even though its not the prettiest.
Do cotic do without the shock does anyone know?
There has to be more out there than those 2 though.
Posted : 12/05/2021 7:37 pm
Available / not too expensive and meeting the brief I’m not sure there are many alternatives. Commencal worth a look maybe?
If it comes down to the AM9 vs Cotic I guess you just need to decide what the Cotic does better for the extra money.
One is 4 bar (AM9), one is linkage controlled single pivot.
I’m guessing the Bird is lighter frame wise?
The Cotic is perhaps a little bit more special to people who like skinny tubed steel.
Does the geometry on both hot your requirements?
Both are decent companies so I don’t think you can lose either way.
Posted : 12/05/2021 7:48 pm
Not sure, but I doubt it as IIRC they only warranty frames with the OE shock fitted, so wouldn’t make sense to sell without. (Happy to be corrected)
Posted : 12/05/2021 7:49 pm
If they did it in Orange, this post wouldn't exist, ha! current colours are just dull and uninspiring (to me at least)
Geometry on the Bird i'd adjust by putting a -1deg headset in, other than that, both are roughly what I am looking for geo wise, but am happy to look at alternatives that are a little either side of the brief!
Interesting point about potentially not warrantying Cotics without the shock. seems odd to me if its the right size and stroke.
thanks so far for the replies.
Posted : 12/05/2021 7:58 pm
Oh and Commencal are September/October for the most part, so that rules them out
Posted : 12/05/2021 8:01 pm
Got a Gen1 RocketMax and it’s very capable even with just the 140mm travel. Have upped the fork to 160mm (max warrantied travel) and it’s great fun. Used it everything from days in the lakes to uplift to week long Alps trips and a week with Basque MTB. Test ride one when they open up their demo days and see what you think. It was between that and a Bird at the time I was in the market for a new bike so suspect either would be more than good enough.
Posted : 12/05/2021 8:17 pm
At the moment a Large Raw AM9 is looking like the option i will go for, just got this nagging feeling i've forgotten about something i really wanted. just can't think what!
Posted : 12/05/2021 8:23 pm
Nukeproof Mega?
Posted : 12/05/2021 10:00 pm
I want to know why Bird and Cotic don't make frames like this for people who don't want to go 29.
Edit.
It seems Bird actually may do.
Posted : 12/05/2021 10:50 pm
I want to know why Bird and Cotic don’t make frames like this for people who don’t want to go 29.
They do, the AM160?
Posted : 12/05/2021 10:59 pm
weeksy
Cotic make the Rocket, which is the original 27.5 wheel version of the RocketMax 29er.
https://www.cotic.co.uk/product/rocket
Posted : 12/05/2021 11:05 pm
Because then they'd be something else
I'm not expressing myself very cleary am I
Posted : 12/05/2021 11:19 pm
The great thing about both of those two companies is you could call either of them up tomorrow, speak with someone who knows the bikes inside out, and give their view on whether the frame would work with your shock. You’re paying top £ for premium British brands, you may as well make the most of the pre sales support that goes with with that. I’d start with that.
Posted : 13/05/2021 12:07 am
@benpinnick I'll give you a call tomorrow to discuss the AM9
Posted : 13/05/2021 12:13 am
One of my riding buddies has recently taken delivery of the AM9in raw, can’t say much about how it rides but it looks great in the flesh and it’s done his riding no harm.
Posted : 13/05/2021 12:19 am
weeksy
Cotic still sell the 650b rocket, though, there's no trailbike, no Flare/Jeht in 650b. TBH Cotic's wheel size policy seems sensibly demand-led.
Posted : 13/05/2021 12:35 am
Anyone else click on this thinking it was a typo... 🙂
instagram live has changed my mind on [b]fame[/b]
Posted : 13/05/2021 7:38 am
I'd really like to know who it is with frames that eat themselves and their shocks. Might be nice to warn others in this community of potential problems before we drop our cash on such things.
Posted : 13/05/2021 9:09 am
Raaw Jibb? Or Madonna's are coming in to stock soon.
At the top end of you price bracket. But i would say far nicer than the mentioned options (IMO of course).
I have put a deposit on a Privateer 141. The weight is a disappointment, but i just want something that is bombproof. The misery of being without a bike due to frame failure is too much for me to deal with a second time round! (thats under the assumption that heavy is reliable!)
Posted : 13/05/2021 9:20 am
 a11y
I’d really like to know who it is with frames that eat themselves and their shocks. Might be nice to warn others in this community of potential problems before we drop our cash on such things.
Likewise. I'm sniffing around a replacement 29er trail/enduro frame and knowing my luck I'd pick whatever brand is being referred to here.
Posted : 13/05/2021 9:47 am
Bike weight (to a point) is all in the head, a lb or two in frame weight makes no difference.
During lockdown 1.0, rode the 161 locally, on a set of xc wheels/tyres, was same speed as the trail bike and quicker than the hardtail. (all on same or similar tyres)
Posted : 13/05/2021 11:54 am
Classy company, good to see their designing, manufacturing, QC and testing process is on point.
Posted : 13/05/2021 11:57 am
 Sui
have you viewed the Banshee offerings - Titan and Prime?? Framt + Shock @ £2K. They are very nice frames.. (i've got the Spitty V3 on very small wheels)
Posted : 13/05/2021 12:15 pm
I used to have a bike that ate shocks - clearly a design flaw. Got the first one warrantied then when the 2nd one died & I had to buy a new one I just couldn't ride it. So totally get where you are coming from.
Posted : 13/05/2021 12:49 pm
I'd add the Nukeproof Mega AL to the list.
Maybe the Vitus Sommet too.
Posted : 13/05/2021 12:57 pm
Am9 or Propain Tyee or RAAW
They come from the same factory I think
Ibis Ripmo AF?
I have an AM9 and love it. They are not "cheap" just great value.
Steel has no place in FS designs, flex is not what you want in suspension components so they build heavy. Also single pivots should have gone in the bin with URT years ago, always a very compromised kinematic.
I'd get the AM9 seeing as you already have the shock. You won't be disappointed, although you may buy a coil shock for it sometime.
They do indeed come from the same factory.
Posted : 13/05/2021 1:12 pm
@benpinnick
Interesting. Clearly your bikes are excellent value, I have two friends who I've recommended them to over the years and they have been nothing short of awesome.
Working in the trade over the last decade I've had access to all sorts of exotica at knock down rates. So it's a weird situation to be in paying full retail price 🤣
I do tend to like quirky left field choices but usually regret it.
Are you available for a chat later this afternoon Ben?
Posted : 13/05/2021 1:21 pm
Banshee Prime or Titan seconded.
I have a Prime and it's bloody lovely.  135mm of travel out back but feels more.
Posted : 13/05/2021 2:21 pm
Norco Sight?
Posted : 13/05/2021 9:42 pm
Ok so its lots more (£2600) but a deviate highlander with a 150mm link would be an amazing choice.
Based in stirling (not built in uk) so very available for a chat and Ben is a sound guy.
Look up videos by mctrailrider to see one in action.
Posted : 13/05/2021 10:15 pm
“ Steel has no place in FS designs, flex is not what you want in suspension components so they build heavy.”
Except steel is stiffer than aluminium and Cotic’s steel bikes are a similar weight to comparable alloy ones - and lighter than quite a lot of them.
“Also single pivots should have gone in the bin with URT years ago, always a very compromised kinematic.”
This sentence has been written by someone who knows how to spell kinematic but not what it means. In the last three seasons of men’s WC DH, 2020 had single pivots coming 1st and 5th, 2019 had single pivots coming 2nd and 4th and 2018 had single pivots coming 1st and 2nd. 40% of the top five for the last three years.
Posted : 13/05/2021 10:17 pm
chiefgrooveguru
Except steel is stiffer than aluminium and Cotic’s steel bikes are a similar weight to comparable alloy ones – and lighter than quite a lot of them
And Cotics have aluminium rear ends.
Posted : 13/05/2021 10:35 pm
If its who I think it is on Instragram the video is still there. I think they were just talking about crash damage?
Posted : 14/05/2021 10:48 am
Partial aluminium. The seat stays are steel and the chainstays aluminium.
Posted : 14/05/2021 10:55 am
@Daver27 sorry only just caught up on the thread. You can give me a shout on 0333 444 0629 whenever suits you 🙂
Posted : 14/05/2021 10:56 am
I've seen it too and thought much the same as HH above.
Posted : 14/05/2021 11:24 am
With all due respect I'd suggest you do some research. If you want the bike to do more than one thing well, i.e. plummet downhill, such as pedal well back up or along, then restricting the axle path and shock actuation with a single pivot massively compromises the bike.
Posted : 14/05/2021 12:07 pm
