Insole material?
[Closed] Insole material?
[#1946731]
Got some SIDI - Very comfy apart from the insole - I put a heal raiser as I have very flat feet and they are nearly perfect.
Anyone use some thin spongy, material you can cut to fit just to give a tiny bit more comfort in the toe mid sole region (under the insole) as its nearly spot on - were only talking 1-2mm thick stuff I guess 🙂 BTW I have tried my speccy insoles they just dont fit 🙂
Posted : 31/08/2010 9:56 am
cork
Posted : 31/08/2010 12:29 pm
OK, so, not quite what you're asking and, not sure how they work for flat feet but, look up [url= http://www.wiggle.co.uk/p/cycle/7/Superfeet_Trim_To_Fit_Blue_Insoles/5360036786/?referid=frogoog&source=googleps ]Superfeet[/url] insoles.
Pricey but, IME, worth every penny - I have them in cycling shoes (black version) and walking boots (green version).
Posted : 31/08/2010 12:34 pm
I have considered it but think i'll try and find a cheaper alternaive first 🙂
Posted : 31/08/2010 12:51 pm
 MSP
Superfeet are awful in my experience, depends how badly it effects you, I used to get really bad pain in my feet after an hour or twos cycling, use these http://www.yoursole.co.uk/products/footbeds/softec/response/ now and have no problems. But again they are pricey.
Posted : 31/08/2010 1:04 pm
Right - got some 2mm thick washable flat insoles from Boots for £1.99 - I just wated a littel more spongyness int eh forefoot so hopefully these should be spot on (can be cut to fit ) 🙂
Cheers for the suggestions though :_)
Posted : 31/08/2010 1:27 pm
I can see the OP is satisfied but I have to backup Marsdenman, Superfeet are ace, and do have a return policy/guarantee if you don't like them.
The main thing is that you get them fitted properly and not just buy them off the internet. I originally balked at the price when recommended some on here, but after a couple of hours walking in a new pair of boot I needed something to deal with the sole. So my g/f & I went to an outdoor shop and bought some superfeet (a size larger than the box sizing suggest - we then cut them down - hense my warning a professionaly fitting helps) and walked up Snowdon the next day without the issues we'd suffered the previous day. I now swap them between all my mtb/walking boots, as and when I need them.
Posted : 31/08/2010 1:35 pm
You never know I might be back on here 😉
Posted : 31/08/2010 1:49 pm
+1 for superfeet. get them properly fitted. They don't go based on size but where your arch is. I also run some in the shoe wedges under the forefoot as well in my shoes.
Posted : 31/08/2010 2:09 pm
I have No arch - My feet are flatter than a dolphin flipper - My wife calls then hobbit feet as they are big, flat and hairy 🙁
Posted : 31/08/2010 3:24 pm
