Increase travel Lyr...
[Closed] Increase travel Lyrik ultimate fork ?
 jeb
[#11211607]
Hello
i own a Rock shox Lyrik ultimate 160mm 2.1 RC2 from 2019
will this up the travel to 170mm, and let it ride higher in its travel ???
https://r2-bike.com/ROCK-SHOX-Air-Shaft-Upgrade-Kit-DebonAir-C3-Mj-2021-170-mm-Lyrik-Yari-A1-ab-Mj-2016
Posted : 25/05/2020 10:43 pm
Yes on both counts, but do you actually want more travel, or do you just want it to sit higher? The 2021 springs sit higher, even at the same travel, so you might actually just want the upgrade parts. You can modify your current air spring to effectively turn it into a 2021 model.
Posted : 25/05/2020 11:06 pm
More travel is nearly always better. Most head angles are too steep anyway, and the few mms added to bb height are negligible.
JP
Posted : 26/05/2020 12:31 am
 poah
and some more psi to get it to ride higher
Posted : 26/05/2020 7:45 am
 jeb
i like to have more travel and if it sits higher in its travel,- bonus!
Posted : 27/05/2020 10:45 am
