inbred frame wieght...
[Closed] inbred frame wieghts
[#433858]
anyone know the weight of a 16 inch geared in bred 100mm model
cheers
Posted : 30/03/2009 1:20 pm
about 5lb
Posted : 30/03/2009 1:22 pm
Sounds about right. It's not really the frame for you if you're worried about weight though...
my 1st gen slider was 5lb.
Posted : 30/03/2009 1:25 pm
just deciding wether to trade up to a scandal or a ti frame only real advantage is the wieght saving, looking at 1.5lbs is it work the extra cash?
Posted : 30/03/2009 1:36 pm
up to you - it's more about the feel of the frame rather than the weight loss.
USUALLY alu frames are alot stiffer - the Scandal may be a bit more forgiving than that though.
Ti frames feel different again. Bit odd to be considering frames at £175, £275 and £1K odd though ❓
Posted : 30/03/2009 1:39 pm
IIRC I weighed my slot dropout frame at an ounce or two over 5lb
I know a Merlin Rock Lobster 853 is virtually a pound lighter....
Posted : 30/03/2009 1:44 pm
have an inbred, just got titus motolite to look after for 3 years, had a scandal in the past, just trying ot decide if building a lighter hardtail is worth it, may look out for an 853 rock lobster frame if that is down to about 4 lbs, ti and scandals i think are about 3.5
ta
Posted : 30/03/2009 1:52 pm
Does the RL ride in a way you like?
Posted : 30/03/2009 1:56 pm
