Impossible to get c...
[Closed] Impossible to get correct cable tension on Shadow Plus Mech
[#6192445]
Hi,
A few days ago I replaced my drive train with a Hope Thick / Thin, XT Shadow Plus and a OneUp 42T sprocket, but I can't for the life of me get the shifting to work properly.
I can either adjust it so that it shifts perfectly in the smaller half of the cassette (high gears) or the larger half (low gears), but not both!
If I add enough chain tension to so that shifting is smooth in the high gears, it would appear that there is too much tension to shift to a smaller sprocket in the lower gears.
Vice versa, if I release the cable tension enough to make smoothing from larger to smaller sprocket smooth, there isn't enough tension to shift from smaller to larger sprockets in the higher gears.
The limit stop screws are perfectly adjusted (11T and 42T shifting is perfect), the B-Tension adjuster leaves the mech as close to the 42T as I dare and the clutch being enabled or disabled doesnt make a difference.
It seems to be that maybe the gears are not quite indexed correctly, but as far as I can tell, I followed OneUps instructions properly; remove 17T, 15T and spacer. Replace with 16T and 42T provided.
Any thoughts as I am a bit stumped! Never had this much issue adjusting a mech!
Thanks!
Posted : 15/05/2014 7:15 am
Sounds like either
Damaged/grotty cabling
cable is clamped wrong altering the pull ratio through the arc,
Or
The hanger is bent (unlikely)
Posted : 15/05/2014 7:23 am
If it works fine on either the top or bottom, but never on both, i cant quite see past something happening around the middle where youve taken out the cog to make space for the 42. I know you say you've followed instructions but looking at the cassette, are the gears all equally spaced around the middle bit? Can you swap out spacers / turn the round, anything that might make that tiny adjustment that maybe isn't obvious to the eye?
I haven't done a conversion myself, or read the how to properly, but reading your post you 'removed 15&17 & spacer' and 'replaced with 16&42' - surely you also need a spacer somewhere around the 16?
Posted : 15/05/2014 7:32 am
 chip
That's what I thought bigger gap between the sprockets in the middle would cause this.
You did remove the 17t and the spacer in front of it .
Posted : 15/05/2014 7:37 am
 cp
Have you got the cable clamped around the right side of the clamp bolt on the mech. I've had exactly the problem you describe when didn't pay enough attention and clamped it on the wrong side.
Posted : 15/05/2014 7:46 am
I'd suggest you get the hanger alignment checked properly first(i'm amazed how many are actually bent, even new ones)as no amount of new bits and adjustments will solve a bent one. Once you know that's correct, move on to the cable, poor shifting in only one direction usually points to cable problems, replace inner and outer with good quality kit, and make sure you have smooth routing.Incorrect B-tension can also cause poor shifting, and unfortunately, setting it for a sprocket it wasn't designed to accomodate, will move it away from the rest of the block, maybe by enough for it to become a problem like yours, maybe not, but worth considering nonetheless.
Posted : 15/05/2014 8:01 am
had the same set up and it worked fine….wrecked the mech a few weeks back got a new one and could not get it to go through all the range…tried everything.. then admitted to myself indexing gears is a dark art and took it to LBS… PROB SOLVED.
Posted : 15/05/2014 8:05 am
I'm pretty sure its meant to be around 5mm gap. Too close and it messes the shifting. I'd be looking at mech hanger alignment though too
Posted : 15/05/2014 8:16 am
 chip
One up you say, did that include the free 16t sprocket.
I think I remember reading recently other people having shifting problems where the one up 16t was found to be the cause.
Posted : 15/05/2014 11:51 am
I've the exact same problem. Only thing is that I've not got a 16 tooth fitted,just the original 15. It's getting a bit annoying.
Posted : 15/05/2014 12:54 pm
 chip
The main reason why I chose the hope expander over the one up was the fact hope made theirs dedicated shimano or SRAM, as I thought a universal sprocket may suffer when shifting.
Posted : 15/05/2014 3:16 pm
Thanks for the feedback. I will go and check my cassette again just to make absolutely sure that I have all the spacers in the right place. Have to admit, it does sound like there is a spacer wrong, even though I am almost certain I got it right!
In terms of checking if the alignment is out on the mech, how do I do that? Visually looking at the top and bottom jockey wheel, they seem to be dead in line. Is there a more scientific way of doing it?
Maybe I will try removing the 16T as well and putting the OEM 15T back in.
Posted : 15/05/2014 5:12 pm
