....will i have any problems sourcing a bottom bracket for it? are they normal square taper or their own design?
any pointers to a decent priced bb for a 68mm shell? its a campag mirage if that makes any difference?
thanks
You can still get square taper Campag bottom brackets from here:
http://www.parker-international.co.uk/c/35/Bottom-Brackets.html
Ribble cycles also sell them.
The Veloce one would be a good budget option, the Centaur if you want to spend a little more. The more expensive ones are probably super-light but not any more durable. I've done over 10,000km on a Veloce one.
You want 111mm length for double chainset and 115.5mm for triple. Campag use a European taper (ISO), whereas Shimano (for example) use a Japanese (JIS) taper. You can interchange them but the chainset will sit on the taper differently and affect the distance from the bottom bracket to the cranks (the Q factor).
Sadexpunk - if you are looking for a campag square taper in Lincoln then have a word with Barrons cycles in Stow. They have sorted me out with a few in the past.
ah right, excellent. so im right in thinking i need an ISO bb then or else chainline will be out.
matthew, thanks. ill give them a ring monday. i dont work too far from there.
cheers
just looking at that veloce bottom bracket, am i right in thinking id need a different bottom bracket tool for campagnolo?
ta
I have used Campag sq taper chainsets on Shimano sq taper b/b before apparently it should not work but it did for me
You'll need one of these for veloce bb removal:
[url= http://www.parker-international.co.uk/1699/Park-BBT4-Campag-Veloce-Bottom-Bracket-tool.html ]Parker-International[/url]
I've got a VAR tool which I bought in Decathlon, but I can't find any info on.
EDIT: Which I've just found.
[url= http://www.vartools.com/catalogue_uk.pdf ]Page 19, BP-60000[/url]
Im currently selling a campag road chainset with bb on the bay.....
Just under 1 day left!
Mirage is the cheap set why bother?
cos i cant find anything else 🙂
been offered a couple of other compacts, but theyre £100 jobbies when bb shell facings taken into account.
stoney, im after compact thanks 🙂
You should be able to find a Tiagra compact and bb for about £70. Facing isn't necessary IMO.
