ICE Lift V8 seatpos...
[Closed] ICE Lift V8 seatpost
SCHWEIZ, Ill measure the distance from the top of the red collar, to the seat rails on my ICE, and if you do the same on your TMARS, we can put this to bed.
Posted : 11/12/2012 1:21 pm
The Collar/Rails on the ICE V8 is 138mm
Ive just been reading the FORCA website, in my dodgy German, and it looks interesting. No Rubber collar to keep the crap out though.
These posts coming in at this price point may force the big boys to act on price, which can only be a good thing. When you look at the RRP for a Gravity Dropper, compared to these, its makes the eyes water!!
I had my first big ride on my ICE V8 yesterday. It needed a bit of fettling on the cable tension. At first, the seat kept disengaging from the upper position and dropping. It required a trade off between lever throw, and pin engagement, but got there in the end!!
Posted : 11/12/2012 1:34 pm
dantsw13
Not sure if collar to rails is the key measurement in question here. I thought we were trying to confirm the travel of the post. Anyway, I'll check both tonight and update you.
Ironically, I will be looking to modify my post to reduce the travel. My fatbike has a very large frame and I have limited exposed seatpost. I will most likely only use the halfway position and the fully down position. I'll try to implement a mechanical stop and possibly add another position to the travel if needed.
By the way, there's a new UK based listing for the post which has photos with measurements of the 3 positions which essentially confirms it's 110mm travel:
http://www.ebay.co.uk/itm/TMARS-REMOTE-ADJUSTABLE-27-2mm-DROPPER-SEATPOST-3-REMOTE-HEIGHTS-/251192301320?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item3a7c3a5708
Posted : 11/12/2012 1:54 pm
excellent.. cheers for that link Schweiz.. Will ask if santa can get me this
Posted : 11/12/2012 2:06 pm
Schweiz, I agree, but I reckon the Collar/Rails is a pretty good indicator of max drop in a coil sprung post, and its much easier to do!!!!
That ebay ad looks pretty conclusive!!
The V8 at max extension only just works on my frame too.
Tempted by the TMAR version for my 456C which has a lower seat tube than my Titus
Posted : 11/12/2012 2:07 pm
Cheers Schweiz for the info
Posted : 11/12/2012 4:08 pm
OK, I can confirm that it's a 110mm drop and the dimensions in the pictures on the ebay link that I posted are correct.
I can recommend ebay seller hotcrazybike2011 from Taiwan. I had it within 1 week. Low customs value declared so no additional charges. He's £65 with free postage and the new UK seller is £67 + £5 postage.
Not sure when I'll get round to installing the post but I'll give you some feedback when I do. I've got a Joplin, KS-i950 and Reverb so I've got plenty to compare it against...
Posted : 11/12/2012 9:07 pm
Dare I ask how the actual weighed weight is looking??? (for such a good price!! (he says wishing for the moon on a stick :D))
Posted : 11/12/2012 9:39 pm
yeah i'll take UK for £7 price difference. got quick responses from the uk seller he sounds legit.
would like to know weight as well.
Posted : 11/12/2012 9:53 pm
Not going to be able to weigh mine until tomorrow night but the Taiwanese seller claimed 659g including remote for the 27.2mm 425mm length. He was spot on with all other information so I don't have any reason to doubt him.
Posted : 11/12/2012 10:15 pm
ebay uk seller tells me weight is 595g inc. remote and cable. and it's not a standard cable. hmmm not sure how you're supposed to replace that then.
Posted : 12/12/2012 1:58 am
 spev
I ordered one from that ebay link two days ago,just waiting for it to arrive (its been shipped so i'm expecting it today), as soon as it's fitted i'll let you know how it goes
Posted : 12/12/2012 9:38 am
The fitted cable may not be standard, but I can see no reason it couldn't be replaced by a standard one when required. as long as you changed inner and outer together. Maybe you may need a new inline barrel adjuster, but i doubt it.
Posted : 12/12/2012 10:25 am
the lever looks identical to the Joplin remote and Ive replaced Joplin cables with gear cables. Be useful for an "early adopter" to see if the cable can be swapped with a gear cable.
Posted : 12/12/2012 11:34 am
Would like to know this too before I press the buy button.
Posted : 12/12/2012 5:29 pm
 spev
As soon as I get to work tomorrow i'll strip it down and have a look ok
Posted : 12/12/2012 5:53 pm
This looks identical to the one I bought via R53 sports and having deliberately not cleaned for the last month it still works fine.
Slight bit of rotational play from new but unnoticeable when riding, while this looks a bargain the service I've had from R53 makes what I paid seem worth it.
Posted : 12/12/2012 6:18 pm
Only the one r53 is selling appears to to be the 90mm drop as opposed to thge new design which is 110mm (which i think most people are after)
Posted : 12/12/2012 6:59 pm
Aye the ebay sellers do seem to offer conflicting weights so an actual would be great Schweiz, cheers 😆
Posted : 12/12/2012 10:55 pm
Guys can you help me please. Currently I have a Trance with a reverb which is awesome for me..I am upgrading to my sons cast-off orange which needs a 27.2 mm dropper. I'm really confused about what to replace the reverb with ...any advice would be great.
Merry christmas Eve..
Mel
Posted : 24/12/2012 8:37 am
Has anyone bought and tried one of the TMARS posts?
How are you getting on with it?
Posted : 26/12/2012 1:49 pm
got one in my stocking. one ride so far.. liking it, takes a bit more thought to use than a hydro post as you need to locate the positions, and real danger of delivering a whack to the nuts if hovering over seat when released!
remote is very nice (had no remote on previous post so any is nice, but this one seems a good design, parallel to grip and can be pushed any way, not sticking out like reverb, and is split clamp). very quick and easy to fit. forgot to weigh it sorry too excited to go ride, this is on my crap conditions bike so i'll know pretty soon (maybe a month) if it's going to be reliable or not.
price has gone up £3 😯 😉
Posted : 27/12/2012 2:57 am
I've put some miles on mine in the last week. Very happy with it so far. It's great value for £65. There's a technique to using it which needs to be learnt. The pin engagement was a little tricky at first but it seems to have worn in nicely and is less clunky now than it was originally. Screw out the spring tension bolt in the bottom of the post a couple of turns if you're planning on fathering (or mothering) any children in the future. Alternatively screw it in for a quick trail side sterilization.
Posted : 27/12/2012 8:59 am
Awesome, much appreciated guys, that seems to be enough of a real life review to convince me to order one ASAP!
I assume for a 30.9 seatpost I'd have to purchase the 27.2 model and a good quality seatpost shim? Don't mind too much as with a 110mm drop it's still the cheapest new post out there with half decent travel, plus I like the idea of being able to service it myself with a bit of head scratching.
Posted : 27/12/2012 9:52 am
with screw slackened off does it still extend to top ok?
good idea to grease or oil the inner steel parts?
god damn this weather is bad.
Posted : 27/12/2012 12:58 pm
4 rides now (mars one from ebay)
[img] https://encrypted-tbn2.gstatic.com/images?q=tbn:ANd9GcQhFztwCy9U7KGiOOLCJBtebnMbHk_hd7HkPjvsGInJW4UxsigpPA [/img]
lovin' it.
only not sure about stop positions.
top, nearly down, down.
i'd maybe prefer top, down a bit, fully down.
as i only seem to use the first two.
hmm - ?
Posted : 02/01/2013 2:05 am
Hi, I also got the TMARS post over Christmas. Haven't been out on a ride with it yet but it seems to be what I was after. Has anybody made an attempt to shorten the remote cable? If so what end did you cut? Thanks in advance.
p.s. I found this link which may help some people http://emtb.pl/emtb/sprzet/test-regulowanej-sztycy-el-gallo/
Posted : 05/01/2013 3:02 pm
Got the TMars ebay version before Xmas and have bounced around on it for a few days now... I have a Bionicon Supershuttle with an awkward 30mm post diameter so ordered a shim from CRC...
I'd say It's fairly agricultural engineering, and has developed some play... The nose of my saddle can rotate 4mm to the left and ditto to the right... But I never notice riding, in fact having a bit of rotation perversely seems to help with pedaling.... But for the money I'm pretty impressed. Last ride the saddle somehow dismounted itself from the post after a clipped-in double somersault down a dune face, but the post is absolutely fine, no damage, seat went straight back on.
Does anyone know how to shorten the cabling? I'd like to nip 10cm off....
Posted : 05/01/2013 9:30 pm
alright had mine apart for a greasing, few notes:
- main tube with spring full of sharp metal shavings, anyone else? left over from mnfr? weird, didn't look like anything was missing or worn.
- gonna need new plastic guide blocks at some point, anyone know cheap source?
- height holes (3) are evenly spread and would be easy to add your own. less easy to take them away - ? top and bottom holes chamfered presumably for easy engagement, might do same for middle.
- the rubber boot has a direction, much swearing after getting saddle back on with it half unhooked. hate hate hate this type of saddle clips.
- would like to have to push less far on remote to release, have to look at this next. i guess cable can tightened.
- isn't rusting as bad as i expected.
- way better than trying to work on a joplin!
Posted : 17/01/2013 1:50 am
After 4 rides, mine is a bit of a pig. I've had the saddle ping back undemanded, I've had the saddle not come up, cable tension needs constant adjustment.
I think a full strip is in order. I might also replace the whole hose with some decent cable outer.
Posted : 17/01/2013 10:02 am
Not the ice post but a heads up re this generic group of cheaper posts...
Cannock grit was tough on my traildrop for the three months I had a 27.2 version...had to service every 3-4 of rides even with a boot or it would start getting sticky. Eventually stopped returning without a pull on the saddle to help....next service revealed a useful bit of info........
[url= http://farm9.staticflickr.com/8466/8388225659_9a3aef7fc5_b.jp g" target="_blank">http://farm9.staticflickr.com/8466/8388225659_9a3aef7fc5_b.jp g"/> [/img][/url]
[url= http://farm9.staticflickr.com/8493/8388225539_af46175f31_b.jp g" target="_blank">http://farm9.staticflickr.com/8493/8388225539_af46175f31_b.jp g"/> [/img][/url]
[url= http://farm9.staticflickr.com/8511/8389313740_e04800c4e8_b.jp g" target="_blank">http://farm9.staticflickr.com/8511/8389313740_e04800c4e8_b.jp g"/> [/img][/url]
.....and it's now back to a rigid with potential disaster averted. My advice.....service and check regularly!! (me 44 and 92kg on a soul, no major offs and occasionally a couple of feet airborne but nothing crazy. Maybe there's a reason they're all cheap or maybe only for smaller guys in the 27.2 format??).
Posted : 17/01/2013 10:08 am
*Goes to check V8 post* 😯
Mine is fine, I slatehered the boot in silicone grease and put waterproof grease inside the post. It's clean as a whistle in there despite some very grubby rides.
Mine was sticky at first but once the plastic guide bush had worn a bit it works fine. Compared to the reverb on my other bike it is clunky and horrid really but it does the job.
Posted : 17/01/2013 10:31 am
Kiwifiz, did you have the cable routing at the front or at the rear of the post?
Posted : 17/01/2013 12:23 pm
i suspect the metal shavings i found were from the steel spring bottom end rotating against the silver alloy bottom cap. there should be a plastic piece betweeen spring and end cap? anyone confirm please?
as for those cracks above.. yikes. it's fairly thick steel on mine, how thick is yours?
Posted : 17/01/2013 1:54 pm
@BillOddie.....standard rear cable routing
@smiff....hole in profile above shows thickness. Key word being hole/holes in this particular model being potential structural weak points. Imagine fairly similar throughout these generic posts? It's hardly going to be high end steel at the cost I'm guessing....
Posted : 17/01/2013 9:16 pm
Took my post apart today, cleaned and greased it - working a treat now.
Posted : 22/01/2013 12:36 am
apparently you can buy any parts on their own, anyone have link for that please?
grease def. helped, action loads better on mine now.
only problem with action is it's a bit too hard to compress to bottom (i'm a lightweight) yet not quite strong enough to reach top if you don't really lift right off the saddle. doubt anything can be done about this.
Posted : 22/01/2013 1:04 pm
I still like my one of these, but I'm finding out little bits as I go along, and generating more questions as well!
I stripped, cleaned and greased a week ago. Two very wet and muddy rides later I felt the need to do it again. I have bodged a mini mud guard by stretching a part slit inner tube over the post and attached to rails with zip ties and sealed with some double-sided. Now seems to be back to condition, but only a real world ride will prove it.
One thing that is really bugging me is that the pre-loader screw plug in the bottom of the post cannot do anything(?) The spring base is held in place by what looks like an immovable inner collar? The seat springs back at a potentially very eye watering speed whatever?
Anyone else puzzled by this?
Posted : 13/02/2013 12:23 am
Mine's a Traildrop. Been on the bike since early last summer I guess. About 3 months after each service I tend to find it doesn't return well, so time for another service. And the rubber boot is now broken at the top (I had it zip-tied on up there).
One question though. I'd like to get the spring out to give the whole thing a better clean. Do others find theirs come out easily? Mine seems to be very well stuck in there. How do you remove it?
To those asking about cable tension adjustment, mine has a barrel adjuster part way along the cable length. If yours hasn't then it would be a useful addition.
Posted : 13/02/2013 7:59 am
 hora
Hows everyone getting on?
Posted : 03/04/2013 8:26 am
My Ice V8 is still going strong. 2-3 months since the last regrease. I think the rubber boot works well on rides at keeping out the crud. As long as caution with the hose/jetwash is exercised, then just the odd strip/regrease will keep it going fine.
Posted : 03/04/2013 10:46 am
I assume all of the above issues are with other seat posts and not the ICE as I haven't had any warranty claims yet.
Posted : 17/04/2013 2:14 pm
My TMARS one is still working great!
No issues whatsoever after 4 months (3 times a week) riding in these lovely weather conditions we've had this year.
Posted : 17/04/2013 2:44 pm
Where can I buy spares ie the sliders and top and bottom collar?
Posted : 17/04/2013 3:01 pm
And it all goes silent again.
Posted : 17/04/2013 4:55 pm
Page 2 / 3
