I spec ev
[Closed] I spec ev
[#11367377]
Have a new bike, brakes and xt shifter are both ispec ev, shifter has the seperate clamp band, how to convert to attach to brake lever, any adapters available(can only see ev to sram, magura or older ispec versions) do shimano do one?I know you can select your clamp option when buying the shifter,?
Ta
Posted : 05/09/2020 5:06 pm
I *think* you'd need part # Y0GT98050
Not sure where you'd get one, Madison (uk shimano distributor) don't appear to stock them.
Posted : 05/09/2020 5:54 pm
Thats the bugger Simon,as you say no stock anywhere(trustworthy anyway), Looks like i’m sticking with the clamp for the meantime. But will keep an eye open
Posted : 05/09/2020 8:12 pm
I'm confused, if both ev they already attach, if you mean your shifter is bar clamp that you want to turn into ev you'll need YOGT98060. Sjs cycles are good for shimano spares.
Posted : 05/09/2020 11:01 pm
Out of stock
Posted : 06/09/2020 12:04 am
