I seem to have...umm.... misplaced mine!
As I run tubeless, and the tyres dont stay "on" the rim when I take the air out, I've been considering getting something like the Joe Blow Boost pump (integrated air cannister) but the cheapest version I've found is £120!
Have also considered getting an Airshot and a standard track pump, which would be cheaper.
Anyone have experience with the Airshot? Or have any other options other than the Joe Blow that is a bit cheaper that I should look at?
TIA hive mind!
I’ve never had an issue inflating tubeless with the Joeblow Mountain X which can be had for around £60. (e.g. Amazon).
+1 for Joe Blow Mountain. It gets new tyres up every time.
If you start swapping around old tyres, sometimes they need more of a kick than what a track pump can deliver.
£120 for a pump! That sounds a bit steep.
Made my own version of an airshot with a 3l drinks bottle, 2 presta valves, and some pvc tube. Think it all cost about £4. Works very well at inflating and seating tubeless tyres with an old Bikehut track pump.
I have an airshot which replaced a coke bottle inflator. It is a joy to use.
Topeak mountain x, just got one and set up some new tyres tubeless with it. Works really well.
Thanks for the input people, keep it coming! 🤣
I have a schwalbe booster which looks the same as the airshot. It works beautifully for the inflation part but I hate the bit that screws onto the valve as it is really fiddly to do as was super stiff on the Schwalbe Booster. A lot of review videos seem to skip over that bit :). If it had a quick release head like lots of pumps do then it would be perfect. I've tried fitting a quick release head but haven't really managed yet
