I need a low stack ...
[Closed] I need a low stack 70mm stem, any ideas?
[#5692588]
Evening all, I recently bought a new frame without checking the headtube size, & well you can guess the rest 🙁
So to save buying some new forks I need to use a short stack headset & stem, the headset I have sorted but I'm damned if I can find a 70mm stem for 1 1/8 forks with a suitably low stack height of less than 35mm (I already have an FSA 35mm stem).
So any ideas? As I said preff 25.4 & 70mm, but could go 10mm either way & I do have a set of 31.6 bars I could use if needed.
Thanks all.
Posted : 14/11/2013 8:03 pm
Hope, Easton, Raceface, FSA etc etc...
Posted : 14/11/2013 8:06 pm
Really, all of those stems have a stack height of less than 35mm? I don't think so 😕
Posted : 14/11/2013 8:18 pm
PZ do some low stack stems.
Posted : 14/11/2013 8:27 pm
Ragley and spank do 35mm
Posted : 14/11/2013 8:29 pm
raceface evolve xc is 38mm, not sure if that helps though...
edit, its not. post read fail.
Posted : 14/11/2013 8:31 pm
[url= http://www.syntace.com/index.cfm?pid=3&pk=2629 ]Syntace?[/url]
Posted : 14/11/2013 8:40 pm
Syntace have low stack stems, 30mm !
http://www.syntace.com/index.cfm?pid=3&pk=2050
My bad.
Posted : 14/11/2013 8:51 pm
Seem to remember raceface d2's being quite low, don't know if they come in 70 though.
Posted : 14/11/2013 8:52 pm
Posted : 14/11/2013 8:53 pm
Many thanks all, some useful info.
It seems the Ragley would be the cheaper option, but new ones I see on-line don't say the stack height, neither doe's the website, anybody know what it is on the new ones?
Cheers.
Posted : 14/11/2013 9:06 pm
I've just had a similar problem. I've ordered a Funn Funnduro from chain reaction. The stack height is 30mm. Nice bit of kit too for £34. I've got a 45mm, but they do a 60mm too
Posted : 14/11/2013 9:28 pm
Bump for the morning crowd.
Cheers.
Posted : 15/11/2013 8:55 am
