I made a new MTB li...
[Closed] I made a new MTB light:
[#7965888]
My old light was a bit bulky (350g) so thought I'd make a new one. I was going to put some new, super-bright Cree XHP70, LED's in it but got sent the wrong ones so just wired it up with 2 old triple XML's.
Will re-wire once the replacements arrive.
I'm quite pleased with it 😀
Posted : 27/07/2016 8:31 am
That looks great. What did you get the weight down to?
Posted : 27/07/2016 8:34 am
235g 🙂
Posted : 27/07/2016 8:39 am
Bitchin' 8)
Expect some speculative 'orders' from folks on here soon.. 😉
Posted : 27/07/2016 8:47 am
Not taking orders on this one, it's just for me 🙂
Posted : 27/07/2016 8:49 am
 Del
looks very smart. side to side adjustment? i can only see up/down?
Posted : 27/07/2016 8:55 am
Stevie, do those front rings in front of the optics screw in with a bottom bracket tool? 🙂
Nice work as usual, which driver are you using and battery?
I've got loads of parts that I haven't used just sitting in boxes!
Posted : 27/07/2016 9:12 am
Cheers GD. Unfortunately not, just circlip pliers. Using a HBflex with a Smudge 15v5.2aH battery.
Any bits you'd be looking to sell? I've got a helmet light I'm working on and need a few bits for that 😉
Posted : 27/07/2016 9:21 am
That is cocking ace.
Posted : 27/07/2016 9:29 am
Cheers PJM 😀
Posted : 27/07/2016 11:14 am
Noticed that the illuminated switch shines through the bottom of the switch and lights the optics up nicely 😀
Posted : 01/08/2016 11:35 am
Nice simple bar bracket,I am falling out with the o-ring style one on mine.
Must sort that out [s]before winter[/s]
Posted : 01/08/2016 11:47 am
Could we press you for a few details of the machining processes?
Do you do your own anodising?
Inquiring minds and all that 😉
Posted : 01/08/2016 11:54 am
Luckily have access to 5-axis machines at work so all done in 6 operations (2 main body, 2 bracket and 2 for the bottom heatsink) as it's possible to machine 5 faces in each set-up.
Unfortunately not 🙁 Got the anodising done by these guys:
Did a cracking job on the light and also did some great 'kashima' anodising on a linkage I made a while ago.
Posted : 01/08/2016 12:03 pm
Stevie,
If I can recover my darkness dominator from Trout, would you be interested in trying to fix it for the appropriate recompense?
Steve
Posted : 02/08/2016 10:38 am
Steve, fire me an email and we can discuss 😉 steve_dees at hotmail.com
Posted : 02/08/2016 10:43 am
Nice light but I'm more interested in the mount!
What is it?
Posted : 02/08/2016 10:46 am
What is it?
It's one I made specifically for this light. Offset to get the centre of the light in the centre of the stem 🙂
Posted : 02/08/2016 10:48 am
That's proper clever. Hat doffed.
Posted : 02/08/2016 11:16 am
Finally got the parts I needed to finish this off properly 🙂
2 x XHP70 LED's @ 5a - it's quite bright 8)
Also got bored and wanted a new helmet light so modified an old Magicshine body I had to take a quad XPL-Hi board and a HBFlex driver. Increased the surface area a bit, modified the insides and it's good for about 4k lumens.
I know, I know, it's not all about how many lumens but how good the beam is. I'll find that out later 😉
Posted : 13/10/2016 9:36 am
Nice looking light!
Hope you've got some monster battery packs though!
Posted : 13/10/2016 10:30 am
My night-rides are only a couple of hours, mostly climbing with short/fast downs. The bar light will do just over an hour on full but only need that for 5% of my rides, on the lowest setting it'll do about 5hrs.
The helmet light is about the same.
Posted : 13/10/2016 10:49 am
Very nice. What optics do you have in there and will you post some beam shots?
Posted : 13/10/2016 11:14 am
Ledil IRIS in the bar light, GT4 in the helmet light. Hoping to be able to do some beam-shots tonight.
Posted : 13/10/2016 11:20 am
