I keep on looking a...
[Closed] I keep on looking at going back to ALU wheels from carbon, silly?
[#7795165]
Built up a set of carbon wheels when i was going through a "everything has to be as light as possible phase", built up some LB 35mm rims with some cx-ray imitations, got what i wanted, killed near enough 400g. They do feel light and fast, noticed the precision and stiffness right away. So as a fast, light set of wheel they're excellent.
However...... I swear i can feel/hear them resonating horribly on hucks to flat and feel "pingy" rather than grippy and conforming.
I'm believing at the moment I should sod the weight, go back to burly alu and the ride will be more forgiving.
Am I thinking BS?
Posted : 27/04/2016 10:34 pm
Are you on a hardtail? I would not run carbon rims on a hardcore hardtail, I hear the rims ringing on the occasional root or rock.
Posted : 28/04/2016 7:11 am
The sound shouldn't affect your ride, but how they feel may. Have you tired different pressures / tyres ?
You could get ally rims that are just as light.
Posted : 28/04/2016 8:20 am
Earplugs would be cheaper.
Posted : 28/04/2016 8:26 am
Every week, someone gives me a new reason to be smug about never upgrading my aluminium rims...
Posted : 28/04/2016 8:28 am
Get a fat bike with carbon rims (that's pimped on two levels) - the tyre noise will drown out any rim resonance 🙂
Posted : 28/04/2016 9:28 am
Mine don't do any of those things. Spoke tension/construction issue? They sound weirdly different with rock strikes, clonk instead of bong, but that's about the only sound difference I can think of
Posted : 28/04/2016 10:01 am
I had lots of carbon wheels, I broke lots of carbon wheels. I no longer have carbon wheels.
My bike rides nicer with 'softer' wheels, easier to hold a line, doesn't seem to get unsettled mid corner & holding off camber sections is noticeably easier.
The icing on the cake at the end of the year for me will be if I haven't broken any rims.
In terms of riding speed, I'm not going any slower, going from a fashionably wide 30mm ID rim to a 23mm rim. No loss of grip either.
Posted : 28/04/2016 10:06 am
What wheel size & hub spacing...? Maybe interested in taking them off your hands if you do 😆
Posted : 28/04/2016 10:24 am
Carbon rims are shit. I will give you £30 for them and I'm doing you a favour 🙂
Posted : 28/04/2016 10:31 am
