Hunt Trail Wide - 3...
[Closed] Hunt Trail Wide - 30mm too narrow for a 'Trail' rim?
That Pinkbike article is junk. If they tried different tyres running at different pressures on a different trail, the results might look quite different.
Posted : 10/05/2020 3:23 am
If you’re lacking sidewall support with a 2.5 on a 30mm rim either stick a heavier casing tyre on there or a set of cushcores. The latter are fantastic if you ride terrain where you can happily run an exo or equiv sidewall without much risk of tearing it.
Posted : 10/05/2020 8:41 am
Why do people compare tyre profiles I thun air? By the time it's at the contact patch, things will be a lot different looking.
I'm not a fan of big balloon tyres and wide rims, much prefer a middle of the road rim width and tyre with proper sidewalls. I never had a eureka moment with wide rims, still had to run it hard enough it was pingy to avoid squirm with trail casings.
When journos go on about
Posted : 10/05/2020 10:56 am
Page 2 / 2
