Hubs for freeride/A...
[Closed] Hubs for freeride/AM hardtail
[#4273682]
I'm just about to buy a Cotic Soul and will be using it for single track riding, including a few descents and drops etc - that tends to be the kind of stuff I ride. Hoping someone can help re hubs and rims as I'm a bit out of touch on that these days.
My current santa cruz has got a 20mm bolt through hope bulb on the front with a mavic 321 disc (doubt they make that any more!) then a hope ti glide on the back that's unfortunately non-disc. I'm going to have to unfortunately replace the back whatever happens as its non-disc. Will I have to replace the front hub? I'm buying a fox float 140mm which irritatingly seems to have a 15mm bolt through. Or does anyone know if I can get a converter to still run my 20mm bolt through bulb?
As for the back - is a hope pro 2 evo a good choice? And any ideas on a decent strong rim to replace it with?
Many Thanks
Jeremy
Posted : 18/08/2012 4:07 pm
 GW
Time to sell your current wheels I'd have thought (don't think bulbs are convertable to 15mm) a set of pro 2s should be absolutely fine,
321s are a bit heavy and OTT for a Soul build anyway so depending on what you weigh and how you ride you could go a lot lighter.
strong and stiff and not too heavy at 570g (ish) - Mavic 721
fairly strong and reasonably stiff but 100g lighter - Stans flow
but TBH if you aren't going to be landing sideways, riding rocky trails fast or need a stiff rim for hard cornering you should be able to go for something around 400-450g like a 717/719 or another stans choice.
Posted : 18/08/2012 4:27 pm
 hora
Hope Hoops are more than enough.
Mine are 2yrs old, pinchflatted and bang down rocks.
Posted : 18/08/2012 4:34 pm
 GW
I agree with your sentiment Hora, actual content, not so much
Posted : 18/08/2012 5:07 pm
Thanks very much for all the advice. Sounds like I'll definitely get a set of pro 2s. Shame, I would like to re-use the front wheel, but sounds like that's not doable.
GW - I do take your point about 321s being overkill, lower weight = lower rolling resitance and all that. I've never heard of Stans and having taken a look, they seem to be tubeless so that rules that out. The Mavic 319/717 look a good bet. However, even the 319 recommends a max tyre width of 2.3 The 717 recommends a max of 2.1. Is that anything to worry about? Like a lot of people, I run High Rollers which are 2.35.
Posted : 18/08/2012 6:01 pm
721 on a Pro 2. No messing around, does the job all the time.
Posted : 18/08/2012 6:02 pm
 GW
I hate tubeless and drill my flows out to take normal tube valves.
719s are prob a better width for larger tyre widths than 717s either wll work tho.
Posted : 18/08/2012 9:49 pm
Flows and other stans rims will give you the option to go tubeless, they do not need to be run tubeless from the start. Arch rims may also be worth a look if you will re-consider stans rims.
Although 719's may not state they can take 2.35 they will be fine on them. If you want to stick with Mavic the have a look at the En521.
Posted : 18/08/2012 10:52 pm
That's great, thanks for the help.
Was a bit worried about the max tyre width, but it sounds like it doesn't matter a huge amount within reason - it's not like I'm running 3 inch tyres or anything!
Posted : 19/08/2012 12:19 pm
 GW
narrower rims will change a larger tyres profile to a more rounded shape. and you run a higher risk of folding the sidewalls or rolling the tyre off the rim if running lower pressures.
Posted : 19/08/2012 4:12 pm
 br
[i]fairly strong and reasonably stiff but 100g lighter - Stans flow
[/i]
I'd go for Crest's (have 2 sets on a HT), and 130g saving each end.
Posted : 19/08/2012 5:10 pm
 GW
I wouldn't! Flows are noticably flexy compared to 721s (especially on a hardtail) lighter weight but construction with similar material can do that.
it's good we're not all the same, eh? 😉
Posted : 19/08/2012 5:20 pm
 br
[i]I wouldn't! Flows are noticably flexy compared to 721s (especially on a hardtail) lighter weight but construction with similar material can do that.
it's good we're not all the same, eh?[/i]
True, but at (only) 80kg the Crests are solid, stiff and haven't needed any truing over the past year - Scottish Borders based and HT, so you can imagine they get a reasonable beating.
Posted : 19/08/2012 5:25 pm
