hub bearings help
[Closed] hub bearings help
[#10939276]
been given the task of replacing the bearing on a friends sons wheels off a cube stereo 2016
https://www.evanscycles.com/cube-stereo-140-hpa-race-2016-mountain-bike-EV264261
wheels are DT CSW AM 2.7 Straightpull wheelset. They look like a rebranded DT hub anyone any ideas as to the bearings likely to be within. I'd like to have replacements in hand before I set about changing everything.
Posted : 30/11/2019 3:22 pm
If you pop the end caps off you should be able to read the bearing numbers on the seals.
Posted : 30/11/2019 5:16 pm
