HT pedals rebuild h...
[Closed] HT pedals rebuild help
[#12208914]
Got some HT flat pedals that need bearing replacement.
AE-03 - which is an EVO+ axle.
I can find the replacement parts in a kit at a reasonable price.
But severely lacking is any instructions or even an exploded diagram on how to do it, and whether the (£110!!!!) tool kit is necessary.
Seriously £110. Pretty sure thats more than the pedals themselves. Wouldnt have bought them if I knew.
Posted : 25/01/2022 2:21 pm
selfish evening crowd bump
Posted : 25/01/2022 6:31 pm
Not familiar with the pedals but looking at the parts / tools they should be handy enough to strip & rebuild.
You might just need a thin walled socket & instead of a tap, use a drill bit to remove the bushing.
If it’s evo+ axle, there’s a video here
Posted : 25/01/2022 6:49 pm
I assume you mean manually ram the biggest drill bit that will fit in there and pull, to get the old bushing out, rather than actually using a drill?
That video (I've just flicked through) seems to use the dummy pedal shaft type thing to seat the new bushing. Could I just hammer on the actual pedal shaft to seat it?
Posted : 25/01/2022 6:55 pm
Yes, just a drill bit and pull it out with it.
You COULD gently use a cordless drill too I guess……
The bushing will be supporting the axle in the body so you should be able to install it with the axle.
Posted : 25/01/2022 7:09 pm
