How to soften a ela...
[Closed] How to soften a elastomer spring?
 Earl
[#9385743]
My kid wanted a suspension seatpost. The only one i could find that would fit the 26.8 seat tube has a elastomer spring. The spring looks in good condition but its too firm for her weight.
Is there a way to make it softer? Drill a hole through the centre or lots of holes through the sides?
Posted : 16/06/2017 5:07 pm
holes through the sides, then you can start with a few small and see how you get on, add more if needed?
Posted : 16/06/2017 5:22 pm
Only ride it on a warm day?
Posted : 16/06/2017 5:44 pm
Isnt there a bolt in the bottom of the seat post which compresses it.
Posted : 16/06/2017 5:56 pm
Isn't there a bolt in the bottom of the seat post which compresses it.
pre-loading or pre-compressing a spring doesn't change it's rate though, just the amount of force required to initiate movement.
BITD when I had elastomer forks with a limited range of elastomer grades I drilled small holes through the sides.
Posted : 16/06/2017 6:01 pm
 Earl
Warmer that today????
Thanks folks - drill coming out.
Posted : 16/06/2017 6:16 pm
Aye. Drill it out. Its just holes held together by rubber. More holes is not a problem.
Posted : 16/06/2017 7:15 pm
On my 150 mm flexstem ,I drilled tiny .5 mm pilot holes through it
Posted : 16/06/2017 8:50 pm
 Earl
Just a update.
I needed it a lot softer. Drilling worked a treat.
Started off drill bit 1 around a cm apart. Tested, redrilled, tested etc.. Ended up with bit 5. Looks like Swiss cheese - very happy kid.
Thanks all.
Posted : 19/06/2017 1:42 pm
