How stiff should th...
[Closed] How stiff should the bearings be on a bottom bracket?
[#1001746]
I've just bought a Boardman Pro mountain bike from Halfords. I've noticed that the bottom bracket bearing seemed a bit stiff, so I took the chain off the chain ring and the span the crank, it barely managed one revolution.
Is that just a case of new bearings that need bedding in or is it faulty.
Matt
Posted : 31/10/2009 8:28 pm
Assuming it's a HTII BB then it sounds like there's a tad too much preload across the cranks. Perhaps loosen off and reinstall if you have the tools....
Posted : 31/10/2009 8:29 pm
Its a Truvativ Stylo GXP. Looks very similar to the HTII on my Specialized bike, although there is no plastic cap just one 8mm allen bolt.
Matt
Posted : 31/10/2009 8:47 pm
 br
If its new, just take it back - tell them to sort it.
Posted : 31/10/2009 9:13 pm
Truvativ state that their BBs are slightly stiff when new and loosen up after a short run in period, claim it helps improve life (sounds like BS to me). I did notice it on mine but not to the extent you're seeing. Maybe try it for a couple of rides and take it back if it doesn't loosen up.
Posted : 31/10/2009 9:37 pm
I think its actually an ISIS system. I managed to get the crank off by undoing the 8mm bolt which was so stiff that I had to extend it with a tube.
However even after removing the crank it was still stiff, so it would appear to be a bearing issue and not due to too much preload across the cranks.
Matt
Posted : 01/11/2009 12:16 pm
