how much to cut thr...
[Closed] how much to cut threads in bb shell?
[#1313813]
As my lovely cheap powder coat is now not so cheap?
Posted : 10/02/2010 10:13 pm
Try some paint stripper if it's just powder in the threads.
Worked for me when they coated my bb threads.
Posted : 10/02/2010 10:20 pm
slight hijack... but i messed up an old fsr frame by crossing the threads on a square taper bb, frames been sitting in the garage now for a couple of years and have often wondered if i could get it re tapped or something??
Posted : 10/02/2010 10:25 pm
Paint stripper might not touch powder coating. You might be able to pick it out or its a five minute job in the lbs with the right tool
Anotherstan - it can be fixed - maybe just chasing the thread again - cheap - or a threaded insert - expensive or a threadless bb is available
Posted : 10/02/2010 10:28 pm
SSS you are a genius
Posted : 10/02/2010 10:29 pm
TandemJeremy - Member
...threadless bb is available
do you mean a pushfit or something similar? wouldn't i need to completely remove the remaining threads for that to work (not really sure how they work 😕 )
by the way tj, my helmet saved my life on monday at kirroughtree 😉
Posted : 10/02/2010 11:15 pm
I think Charlie the BikeMonger does a threadless BB - the two sides basically tighten against each other rather than relying on the threads. Worth an email.
Posted : 11/02/2010 12:02 pm
I'm sure I've heard of framebuilders gluing in a new threaded shell into alloy bbs. No idea how much.
Posted : 11/02/2010 12:06 pm
i installed a BB incorrectly resulting in messing up the BB threads in the frame. i went to my LBS and they re-threaded the BB for around £15-20 and all works again.
Posted : 11/02/2010 2:58 pm
I have a thread chasing tool, though I've never had the chance to try it out as I'm too hard on my bearings 🙂
Posted : 11/02/2010 3:11 pm
If you are a regular at your LBS then they should be able to sort it out for not too many £££'s.
Posted : 11/02/2010 5:12 pm
Green Nitromors will do it. Use a stanley blade to break the continuity between the paint you want to strip and the paint you want to keep. on the BB this will be the outer edge of the BB face.
If you don't do this, the pain stripper can swell the paint you want to keep.
Posted : 11/02/2010 5:28 pm
