How much SP41 to or...
How much SP41 to order.
[#12468027]
Bike not with me. How much roughly for rear gearing and dropper post L hardtail.
4m ? 6m ?
Thanks
Posted : 19/07/2022 2:21 pm
3m is lots, 1500m brake hoses always need trimming
Posted : 19/07/2022 2:28 pm
4m will be plenty, stock brake hoses are around 170cm on Shimano brakes as a comparison I believe.
Posted : 19/07/2022 2:29 pm
FWIW I've always just gone for a 10m roll - if you maintain your own bikes you'll get through it sooner or later, and buying a shorter length just means you're more likely to end up with an offcut that's too short to be useful.
Posted : 19/07/2022 2:44 pm
FWIW I’ve always just gone for a 10m roll – if you maintain your own bikes you’ll get through it sooner or later, and buying a shorter length just means you’re more likely to end up with an offcut that’s too short to be useful.
This +1
Or at least order a cost effective amount if it's not freepost.
Now that everything's continuous outer, thanks ironically to internal cabling, then it's likley to be ~170cm for the gears and ~120cm for the dropper. So 4m leaves you with an offcut too short for either to be any use.
Posted : 19/07/2022 2:56 pm
50 Metres - anything shorter and it's ludicrously overpriced.
Will last you pretty much forever - treat it as an heirloom. ;o)
Posted : 19/07/2022 4:42 pm
Went through this myself. 50m purchased in the end £/m better. Hope to be able to ride long enough to use it up and help mates out.
Posted : 20/07/2022 7:53 am
Depends how many bikes you do or will end up looking after.
I did the same as the last few posters. Always found myself scrabbling around or ordering a single use kit when servicing / repairing one of the half a million bikes I seem to get stuck with.
Bought a 30m roll of Clarks outer for something like £20 from Amazon and a bag of 100 cable ends and ferules, along with a batch of 20 inner cables for road/mtb.
Posted : 20/07/2022 8:32 am
I've had a roll of Clarks for 8 years or so. Plus a massive set of cheap inner cables.
Very convenient. And it has helped me help a bunch of mates out over the years
Posted : 20/07/2022 8:35 am
n.b. a lot of the benefit comes from sealed cable ends so it's worth going for at least not the cheapest ones.
Posted : 20/07/2022 11:08 am
Just make sure you buy good inner cables that have been wound and ground smooth. If they've got a non slip coating that's even better. it makes quite a difference.
Frustratingly it's almost cost effective to buy the cable kits Shimano make just so you get decent inners and a limited supply of ferules and cable ends.
Posted : 20/07/2022 11:43 am
So what (gear) outer do people recommend? (I'm nearly out of my last roll)
Also, what are the best cable ends?
Supplier recommendations needed for both - it seems difficult to buy cable ends between small packs (where they're over £1 a time) and massive pack (expensive and more than will ever need).
Posted : 20/07/2022 12:36 pm
