How much pressure a...
[Closed] How much pressure advice
[#2951027]
Does anyone know the max pressure you can fill a rp3 shock?
Posted : 16/07/2011 5:12 pm
not sure if it still applies, but the recommended used to be pressure approx equal to your body weight
Posted : 16/07/2011 5:20 pm
it should say on the shock body, iirc it's around 300psi
Posted : 16/07/2011 5:36 pm
Thanks for the info. No info on the body, just trying to set the sag, being a chunky monkey, got to 200psi and wondered if this is over the recommended pressure. 220psi is just right! Thanks
Posted : 16/07/2011 5:42 pm
