How much difference in performance - forks?
between
[url= http://www.merlincycles.com/bike-shop/frame-forks/forks-shocks/rockshox-suspension-forks/rockshox-revelation-rl-forks-2013.html ]these revs[/url]
and
[url= http://www.chainreactioncycles.com/rock-shox-sektor-gold-rl-dual-position-coil-15mm-2014/rp-prod109678 ]sektors[/url]
thinking about damping rather than spring
Damping appears the same. Differnces in weight and spring type.
The coil will likely give a more supple ride but less cost friendly tuning.
how do these sektors on crc differ?
[url= http://www.chainreactioncycles.com/rock-shox-sektor-gold-rl-dual-position-coil-15mm-2014/rp-prod109678 ]Expensive[/url]
[url= http://www.chainreactioncycles.com/rock-shox-sektor-rl-dual-position-coil-forks-2013/rp-prod85087 ]Cheap[/url]
Both dpc and rl - one is "gold" the other isn't?
Dual flow on the rebound on the revs so won't 'pack down' as much on repeated hits and a DNA moco as opposed to a standard moco, not a huge difference performance wise but slightly lighter
so the revs are better then? did you get my email re lyriks and oil volume?
The RCT3 damping circuit is much much better than anything else on a Revelation [url= http://www.bike-discount.de/shop/a97953/revelation-rct3-dpa-150-maxlelite-15-black.html?lg=en&cr=GBP&cn=gb&gclid=CNPN09vKsboCFfHItAod32AAiw ]German bike shop forks[/url]
Yes revs in rl, rlt or RCT3 are better damped than the sektors.
No didn't get a mail, fire it through again. 😀
I thought RL Sektors were lighter than the equivalent Revs?
I've had Sektors (RL Air) for best part of 2 years and are spot-on as value trail-centre fork. A downside of the Sektor ime is that they seem difficult to get right in terms of pressure, i.e too much and they like a pogo stick, too little and they munch straight into their travel on steep stuff and drops (as much to do with my technique probably) 😉
Revs are smoother though imo.
