How much advantage ...
[Closed] How much advantage is suspension, gears?
Two options.
#1
Look at the results of any 12 or 24 hour race with a seperate singlespeed class.
How many laps did the overall winner do ?
How many laps did the SS winner do ?
That's the difference.
#2
Hire a bike with gears and suspension.
Time a lap of a test route on your bike.
Time a lap on the hire bike.
Posted : 11/07/2010 1:44 am
MilitantGraham - Member
#2
#1 won't work because they are different riders - but I have looked at it.
#2Yeah, that's basically what I'm going to have to do.
I was hoping some research had been done on this previously and that I could be pointed that way.
I find it amazing that the advantage has never been quantified.
I'll build up an Alfine wheel tomorrow and give it a whirl.
Posted : 11/07/2010 2:01 am
get super niche and get yourself a rigid 29er ss that will certainly be faster.
Posted : 11/07/2010 2:19 am
metcalfe - Member
That's what I ride at the moment 🙂
This thread has totally destroyed my image of STW riders. 🙁
Based on the amount of threads where the emphasis is on going fast and performing amazing feats, I had visions of finely honed athletes who tested every little thing to check its incremental value to their performance.
The sort of people who wouldn't hesitate to use the [b][u][url= http://sheldonbrown.com/chainclean.html ]ShelBroCo[/url]
[/u][/b] chain maintenance regime to gain half a second per lap. Now I'm not so sure.
I had hoped there would be one who could spare a crumb of fact. Unfortunately the thread remains fact free.
However the STW crew have been extremely generous with their opinions which unfortunately have fallen on stony ground because I already have such an excess of opinions that I am often voicing them to ungrateful ears.
Or could it be that I'm wrong, and that you are all competing in the World 24 Hour Solos and do not wish to give away any advantage? 🙂
Posted : 11/07/2010 10:36 am
There's too many variables in mountain biking to give an exact figure.
I'm sure it would be possible to set up a test rig to measure oxygen consumption and power output at set speeds and cadences with different gear ratios to calculate the exact benefit of having a choice of gears, but I don't know how accurately the results would translate across to a real mountain bike race.
Posted : 11/07/2010 10:47 am
 ctk
Epiccyclo-What bike did you ride before your rigid SS 29er? I can't believe you've never had gears!
My advice would be to buy a set of suspension forks for your 29er and try 'em. Will of course depend on where you test them wheter or not they are faster than rigid or not.
I, for what its worth, have tested my FS bike against a front suspension singlespeed around Sherwood Pines and I was faster on the FS.
I sincerely hope you'll be posting up a thorough, lucid breakdown of your efforts, with graphs and maybe a Powerpoint presentation. Extra points will be given depending on how witty the name of the units you will use to quantify performance gains/losses is. We [i]need[/i] this information, damnit!
Posted : 11/07/2010 10:55 am
 Del
that is of course true, but if you look at enough results over enough events, you're probably close enough for the data to be meaningful, or at least indicate a trend. at least as accurate as you riding one lap on one bike and another lap on another bike you're not used to, i would have thought. IMO.
did you really think someone had tried to measure this stuff scientifically?
i use an alfine on one of my bikes but i wouldn't use it for racing. i'm not usually bothered by weight on my bikes ( the alfine'd HT is 33lb! ), but if you're looking in that direction i'd go 1x9 and probably save a couple of pounds. i understand the racers are weight weenies. that's probably for a reason..
Posted : 11/07/2010 11:11 am
My laps were between 61 and 64 mins a lap for my geared 29er HT and 67 - 69mins on my rigid 29er SS at 2010 Mountain Mayhem.
2 laps each in the dry without lights being needed. My night laps were all done on the 29er geared HT.
So: 3-5 mins slower per 9.2 mile lap with 1600ft of climbing.
3.5lbs difference in weight, similar wheels and tyres, identical build kit (other than suspension forks, brakes and mechs + shifters).
IMO I lost most of the time on the flats and downs where I spun out on the SS.
Posted : 11/07/2010 12:15 pm
Daffy - Member
My laps were between 61 and 64 mins a lap for my geared 29er HT and 67 - 69mins on my rigid 29er SS at 2010 Mountain Mayhem...
Thanks Daffy. Exactly the sort of thing I wanted to know. 🙂
ctk - Member
I've got gears on my belt drive Pompino. A S-A 3 speed. 🙂
I gave up on derailleurs decades ago when I suffered an eye-watering GTTI* episode after my lightweight expensive derailleur broke apart on a steep climb and did a roadside single speed conversion.
*Goolie Top Tube Interface
Posted : 11/07/2010 4:37 pm
Page 2 / 2
