I know it depends on a variety of factors but any rules of thumb?
Apparently around 15 mins chap, that's the case with SIS anyway!
"kick in"?
they don't work like that
Thanks!
kick in"?they don't work like that
I know, just lazy shorthand for "be absorbed so you can start gaining the benefit"
it depends on how low your stores are when you take the gel, if you're bonked, TBH it won't do much, but if you're keeping up with your carb intake, you'll feel fine regardless.
be absorbed so you can start gaining the benefitit depends on how low your stores are when you take the gel, if you're bonked, TBH it won't do much, but if you're keeping up with your carb intake, you'll feel fine regardless.
Can't see the logic in that at all. "bonked" usually refers to a depletion in muscle and liver stored glycogen. When you consume carbohydrate it will be available in the blood stream (dependent on several factors as mentioned) for the use by cells. If you are bonked, and will therefore have low blood glucose you [u]WILL[/u] see the benefit once its available.
I did see some availability data recently of when consumed carbohydrate was available for cells but can't find the reference I'm afraid. If I remember correctly gels where a surprising 30 mins. Still quicker than something like a banana though.
Simple sugar such as a glucose energy gel will ramp up the blood sugar level in minutes.
There was an article in Cyclist about this last month, apparently for gels and drinks it's within 10 minutes.
There was research done using carbon markers in different foods and they were picking the metabolites up in breath after 10 min for liquids
I'm diabetic and when I have a hypo on a ride the gel works in 5-10 mins max.
There was an article in Cyclist about this last month, apparently for gels and drinks it's within 10 minutes.There was research done using carbon markers in different foods and they were picking the metabolites up in breath after 10 min for liquids
It does but it also says that only minute amounts are seen within 10 minutes, and presumably having limited effect, with the bulk of delivery at 60 mins where I guess you are beginning to see a useful metabolic benefit.
A good article though.
Listen to him, diabetics know these things as they reply on them to stay healthy.
A few minutes usually, according to my body.
10-15 mins here
Orally or rectally?
DrP
They also have a 'different' metabolism and will actually need the sugars as opposed to thinking they do.
Orally or rectally?DrP
High5 have bought out some new delivery system?
Big clench of the cheeks gets you a squirt of colon gel? What flavour are you preferring as i cant say ive tried them yet (dangleberry fruit burst or fudgeybanana)..
I`d say pretty quick if Chris Froome was willing to take a 20 second penalty for taking one off Porte with only 5 km to go on a stage in the 2013 TDF , he obviously thought it would save him more than 20 seconds by smashing one!
