You probably aren't looking hard enough. And it's torx. Not torts or torqs.
Always helps if you look for the right thing.
Autocorrect. Feel free to point me in the right direction.
Are there any high torque applications for torx?
fourbanger - Member
POSTED 8 MINUTES AGO # REPORT-POST
Removing seized and subsequently shredded hex bolts.
I thought everyone knew that?
Torx is standard on Magura... but usually <15Nm IIRC....
Why not chuck ribe in the pot as well, very underused.
I'm late to this thread but after reading this
Gxp cranks, one bolt, do it tight forget and ride.
If my bladder wasn't empty I'd have pissed myself at that.
And the only time I have had to use a Torx key battered into a hex bolt to aid removal is when a cack handed wannabe home mechanic has used his free ikea home furniture Allen keys to attempt work on their bike.
Without wanting to diss the OP's mechanical skills, why on earth is he attempting to replace a perfectly good bolt when he doesn't really understand how bolts work? Just use decent allen keys on the bolts you've got!
There are so many pitfalls in doing this for a minor (and debatable!) benefit. Unless you're mechanically very competent and know exactly what you're doing it is not worth it! Wrong length, wrong pitch, wrong chamfer, wrong head diameter etc etc.
Can anyone recommend a best value set of "decent" allen keys (and torx keys for that matter) for mtb use?
Bondhus brand for hex keys for the toolbox, I'm not sure about their torx keys though so I'd recommend Wiha torx keys. Very good quality and not too expensive if you look in the right places.
I've got Bondhus T Allen keys and a Bondhus 'Gorilla Grip' multitool in both torx and (metric) hex versions.
A slight annoyance is that the T handle ones don't have an allen key on the short end of the tool like most (E.g. Park) do, which is annoying in some circumstances. The smaller keys (2.5, 3mm) can be quite torsionally flexy, and you can't always get a long tool into every bolt. For that reason I probably wouldn't buy them again. Mine also aren't ball ended, although it looks like the newer ones are, which would help.
But as far as quality and cut of the tools they're great. The multitool ones seem to be the same excellent quality, too.
https://www.amazon.co.uk/Bondhus-Gorilla-Grip-Folding-1-5-6mm/dp/B0006O4AG0
and
https://www.amazon.co.uk/Bondhus-8pc-Torx-Folding-Gorillagrip/dp/B000E7ZLHQ/ref=sr_1_1?s=diy&ie=UTF8&qid=1461934762&sr=1-1&keywords=bondhus++gorilla+grip+torx
