How does a bike &qu...
[Closed] How does a bike "attach" to a turbo trainer?
[#5041734]
Just wondering,
One bike has an Alfine, big headed bolts
One a QR
Other has CK fun bolts Allan key nut
Will they fit?
Posted : 08/04/2013 6:41 am
Mine fits by swapping the qr for a turbo specific one which then clamps into the turbo. Wouldn't work with anything that couldn't take a qr.
Others may vary but I can't see how.
Posted : 08/04/2013 6:44 am
The QR is on my full sus bike! I couldn't use that could I?
So, if I want a Turbo trainer, I'd need to get a new bike? Right?
I'll let mrs Coolhandluke know.
Posted : 08/04/2013 6:58 am
Tell her we've said it's fine.
Posted : 08/04/2013 7:13 am
The alfine nuts are too small to be clamped by my Tacx securely (although it was tight enough to set up for fitting). You need to buy special [url= http://www.evanscycles.com/products/tacx/axle-nuts-m10-x-1-ec042692 ]Nuts[/url] to replace them. I suspect they'll work with CK too.
So no, you don't need a new bike, but you will probably want a new tyre. Tacx also adjust for wheel size, but swapping sizes is not a routine job. The sartori was on offer at Decathlon if you want new. But they are always available used too.
Posted : 08/04/2013 7:35 am
@&!¥ TiRed, what if she reads this now $¥€#
Thought I was on for a new bike then.
Posted : 08/04/2013 7:37 am
I ended up getting a spin bike for indoor training.
Rock solid so you can hammer it and they don't move, the pedal action replicates actual cycling pretty well and there's plenty of adjustment.
I got a NordicTrack GX2. Immaculate condition on ebay, £200. Heavy but once it's in place doesn't matter. Maintenance will be straightforward.
Best money I've spent in a while as my fitness has improved enormously (luckily have someone who knows what they're doing writing the sessions for me).
Get a heart monitor and you're away.
Posted : 08/04/2013 8:05 am
My bike just clamps into the turbo (Elite Gel something or other), no need for a different QR or anything:
You turn the handle on the right until it's tight, then use a locking collar to stop it coming loose when you're training.
If you do get one, a spare back wheel with a slick tyre is a must, you don't need a rear brake so there's no need to get a disc or worry about the braking surface, similarly if it's a heavy old wheel and not 100% straight they won't be a problem.
That said, an indoor spinning bike (as 154hopperavenue says) would be a lot better, it would be a lot more solid and quieter.
Posted : 08/04/2013 9:20 am
Oh dont forget to disconnect your back brake, if you accidentally pull it as i have done in the past the roller keeps on going and can if your not careful rub a nice chunk out of the tyre. This may just be idiot me though lol
Posted : 08/04/2013 9:38 am
Macavity - Member
http://www.lemondrevolution.com/
Not used one, but everything I've read says it's louder than a loud thing...
Posted : 08/04/2013 9:42 am
my elite turbo, works with quick releases and and alfine, just checked. hth
Posted : 08/04/2013 9:47 am
How about Rollers ??
Posted : 08/04/2013 9:49 am
have you seen those funny videos on You Tube of people loosing it on rollers?
Posted : 08/04/2013 4:31 pm
