How do you remove s...
[Closed] How do you remove shock mounts?
 DT78
[#1564065]
Not the actual bushing just the little silver / spacer thingys. All I can come up with on google is how to fit them!
How do you get them out?!
Posted : 01/05/2010 2:34 pm
you just pull em apart usually
Posted : 01/05/2010 2:36 pm
 DT78
Really? They seem pretty tight, was thinking about putting a screw driver in the gap and give it a little wiggle but didn't want to knacker anything.
Posted : 01/05/2010 2:42 pm
If they are worn they just fall out or come off really easily. Maybe put the shock mount in vice and pull on the shock while twisting.
Posted : 01/05/2010 3:06 pm
 goog
pliers
Posted : 01/05/2010 3:10 pm
 DT78
Well a screw driver worked followed by using an allen key as a punch to get it out the other side. Made some marks on the mounts which I wanted to avoid. Ho Hum.
Posted : 01/05/2010 3:23 pm
