bought some s/h forks decal removed been great work fine sold to me as 100mm but just want to check....how do i do that?
Forks on a new frame oh and they are 29er
Thanks
if they are air - let th eaior out and see what travel you get
if spring then you cannot really without removing the spring
You could use a ratchet strap and tension it up via crown and bars but tbh I really would not advise that and something may well break
You can also add a ring or perhaps a cable tie to stanchion and see what you get on a ride - depends on how big a hit you take like- i very rarely get full travel from mine tbh
umop3pisdn ............. :?...........perhaps a badly phrased question but an honest one
junkyard....thanks will try
Zip tie round the stantion, lean over bars and bounce up and down a lot. Or ride off a cliff and land on the front wheel.
it wouldn't have been much of a troll.
Measure the stantion and deduct approx 10 mm
tbh thought there was a lot more techy way to do this............how foolish i am,
measure the length of exposed stanchion then allow a bit for a section that won't get used. Not perfect but should let you know if they are 80/100/120m forks which are common for 29ers. Less relaible for telling the smaller differences like 140 and 150 forks.
actually there suggestions are better for a rough calculation tbh
The amount of stantion visible isn't always an indication of the travel.
no but it lets you know if you definitely don't have an 80mm fork for example.
I got some rebas that the seller said where 100mm. Looked a bit short and measured them and yup definitely not 100. Stripped and serviced them and found a 20mm spacer inside.
