How can I tell the ...
[Closed] How can I tell the difference between Pro2 & Pro2 Evo freehub
[#11454137]
Hub513 and Hub520 for those that care.
Posted : 30/10/2020 7:40 pm
The evo free hub is bigger.
If you have the rest of the hub, the end caps on the pro2 hub have flanges where as the pro2 evo end caps have none, just a plain diameter.
Posted : 30/10/2020 7:46 pm
Pro2 evo ran a thicker axle too, think the bearing id's were 17mm rather than 15mm if memory serves me correctly.Check on Hope's tech site to be sure.
Posted : 30/10/2020 8:16 pm
Measure the inside diameter of the bearings. Pro 2 are 15mm, evo are 17mm.
Posted : 30/10/2020 10:03 pm
