How are stanchions ...
[Closed] How are stanchions fixed in forks
[#6113707]
wanting to remove the stanchions and steerer from some Rockshox Revs
and make a new crown with a view to fitting them on the fatty
just wondering how they are fixed in
Posted : 13/04/2014 5:20 pm
bonded, with a possibility of a heated crown and frozen stanchions.
Posted : 13/04/2014 5:22 pm
You won't get a decent re-bond either, your best bet will be pinch bolts like on dual crown forks. If you smack it with a hammer enough times it should come out but may damage the steerer, no idea how you would get stanchions out but "carefully" is my guess.
Posted : 13/04/2014 6:03 pm
 JoeG
If you're making a new crown anyway, I'd make 2 cuts in the crown to release each of the pressed in pieces. If you got both cuts nearly through the crown, a sharp blow may finish the job by cracking the crown w/o cutting into the stanchion/steerer.
Posted : 13/04/2014 6:13 pm
