HopeTech M4 Bleedi...
[Closed] HopeTech M4 Bleeding
[#1345491]
Is it normal for me to see very tiny air bubbles comming from inside the master cylinder when i pump the brake lever after the bleed nipple has been nipped back up at the caliper end
Andy
Posted : 21/02/2010 12:01 am
yep, thats ok, you know you have to put the diaphragm and cap back on, turn the lever vertical, pump it a few times, put the lever flat again, remove diaphragm and top it up again?i think thats to expel those last few bubbles.
Posted : 21/02/2010 12:04 am
Yes done that cheers....just getting a bit worried like you always do when doing stuff like this at silly O clock the night b4 a early start.....one other thing...is it normal for the fluid to be proper brown/black and shitty even in the master cylinder ??
bike only 10 months old and its only the second bleed of the rears
thanks again.......
Posted : 21/02/2010 12:51 am
I'm surprised that you've bled your rear brakes twice in 10 months. I've been running Mono Mini's for over a year including a week in the Pyrenees and they've still fine. They got really, really hot in the Pyrenees too.
Whoever set them up must have left a few bubbles in the system in the first place...
Posted : 21/02/2010 5:48 am
Go for a ride, fix the brake later. If you kill yourself riding, the un-bled brake won't matter much. Have fun!
Posted : 21/02/2010 7:07 am
Snow stopped play 🙁
Will have to wait two whole weeks before test ride time ....bugga
Posted : 22/02/2010 3:04 pm
