Hope / XD driver en...
[Closed] Hope / XD driver end cap compatibility
[#6933488]
So I have a Pro 2 Evo hub and I'm going to install an XD driver kit. The kit comes (as standard?) with 10mm bolt through end caps.
Am I able to simply pull these off and install standard Hope 9mm QR end caps?
Or does the XD 'driver body' require and XD specific 9mm end cap?
Posted : 15/03/2015 12:58 pm
there's a specific XD end cap for 9mm or 142x12mm...
when i ordered my XXD driver, i was asked which kit i wanted...
Posted : 15/03/2015 1:04 pm
I've found this: http://www.jejamescycles.co.uk/hope-pro-2-evo-xx1-xd-qr-drive-side-spacer-135mm-id83626.html
I'm assuming the EVO axle is fine and I'll just need one of these drive side end caps and a standard 9mm non drive side end cap. Can anyone confirm?
Posted : 15/03/2015 1:08 pm
You need one of what you've pictured, the existing non drive 135mm cap is ok to reuse, axle needs no modification.
Posted : 15/03/2015 2:01 pm
Cool. Had hoped so
Posted : 15/03/2015 2:10 pm
