Hope xc hub help ??...
[Closed] Hope xc hub help ???
[#3740321]
Can't shift the spacer inside the freehub to get at the outer bearing
Help??
Ta
Will
Posted : 04/03/2012 9:28 pm
 nbt
there's a circlip holding in the outer bearing remove that first
then it's a case of using a drift at an angle to move the spacer. You need to be careful not to cuase damage but you might be surised at how much it takes to get it to move
Posted : 04/03/2012 9:34 pm
Thought the circlip was on the inner bearing?
Have been trying to be careful for ages so far ;))
Posted : 04/03/2012 9:58 pm
i followed this
Posted : 04/03/2012 10:01 pm
Cheers folks. Have had the bearing out before but can't seem to get enough purchase on the outer bearing to shift it.
Got the hub bearings out no probs.
Will have another shot tomorrow at the freehub
Posted : 04/03/2012 10:39 pm
