Hope XC Hub Drawing
[Closed] Hope XC Hub Drawing
[#1793351]
I could do with a dimensioned drawing or model of a Hope XC hub. I need to make a spacer to push the disc out a couple of mm. Anyone have one, If not the PCD of a six bolt rotor would be good.
Cheers 🙂
Posted : 12/07/2010 10:00 pm
[url= http://www.hopetech.com/French/technical/tech_XC_REAR.htm ]one of them here[/url]
Posted : 12/07/2010 10:07 pm
No dimensions on that one 🙁
Posted : 12/07/2010 10:09 pm
Could you not just use shim washers?
Posted : 12/07/2010 10:11 pm
I'd rather make a spacer like this [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=3288 ]click me[/url]
But they are not in stock and i would quite like to make one tomorrow at work ready for tomorrow nights ride.
Posted : 12/07/2010 10:19 pm
 Hip
Spacers [url= http://www.velosolo.co.uk/isospacer.html ]here.[/url]
Posted : 12/07/2010 10:22 pm
Thanks Hip, doesn't get me riding tomorrow night though. Anyone else?
Posted : 12/07/2010 10:42 pm
Can you not just measure your hub?
Posted : 12/07/2010 10:56 pm
Appears to be a 44mm PCD by my measurement of a hope rotor, with an ID of 33mm.(Disclaimer- I've got poor eyesight, and it's past my bedtime:))
Posted : 12/07/2010 11:06 pm
Cheers Coatsy, that gives me something to work with for now due to a lack of a drawing. Chunk yes I could, but I really wanted a dimensioned drawing so I could make the profile of the spacer the same as the profile of the hub.
Posted : 13/07/2010 8:29 am
 cp
hmmm, you're not really going to find a manufacturing drawing of pretty much any component online eh...! hole dims is one thing, profile drawing with dimension details quite another. I'd just measure approximately what you've got and get on with it 🙂
Posted : 13/07/2010 8:34 am
Funny I do have a Solid model file of a Mono M4 calliper that I acquired at some point, just wondered if anyone had the obsolete XC drawing.
Posted : 13/07/2010 8:50 am
Use 6 lock rings from presta valves?
Posted : 13/07/2010 9:34 am
Is the spacing a bit iffy on yours too, same as mine, I just bought a XC6 hope wheel set, and I cant get quite enough adjustment on the brake caliper for the rotor to quite centralise in the brake either..odd
Posted : 13/07/2010 10:08 am
Yup I've used washer and tube lock rings in the past.
Posted : 13/07/2010 10:10 am
