Hope XC front beari...
[Closed] Hope XC front bearing removal, help please.
[#1376206]
Done the rear 4 sets due to excellent web guidance.
Can I find any tips on the front .... no
Pulled off one side spacer to reveal a bearing.
Do I simply hit this side, pushing the other spacer off with bearing?
A web link or detailed help would be very much appreciated
Posted : 02/03/2010 9:28 pm
i just did my Hope Mono front hub, bearings came out as you just described (tap axle to dislodge opposite bearing)
Posted : 02/03/2010 9:46 pm
Smack the axle and the other side will pop out. From there it should all look straight forward its much easier that the reverse imo.
Posted : 02/03/2010 9:48 pm
Have you had a look on the hope website?
I don't know this particular hub. is there a circlip holding the bearings in? if so remove it. Bearings usually drift from the cntre out - so with a long drift get into the middle of the hub and knock the centre spacer to one side then drift the bearing out from the centre tot eh outside
Edit - I am thinking about a 20 mm axle hub.
No circlips on the xc hub. Did mine saturday with a big screwdriver and hammer, yeee haaa!!
Posted : 02/03/2010 9:50 pm
front is simples, as above; ding axle and one bearing out then drift the other one. Impressed you've worn out front bearings, mind. I'm still on a 2002 set.
Posted : 02/03/2010 10:59 pm
All done, many thanks. It was quite cathartic.
Posted : 03/03/2010 12:20 am
