hope xc bearing pla...
[Closed] hope xc bearing play
[#456636]
i have alittle side to side movement in my rear hope xc wheel, i assum ethis is bearin play and i'll need ew bearings. Its the same movement as when cones need tightening. Is there anything else it can be?
Is it an easy job to replace the bearings any tips etc?
ta
Posted : 08/04/2009 7:41 am
Probably is bearings but there's an outside chance that it's a snapped axle
Not to bad a DIY job but you need to whack it a lot harder than you think you'll need [or want] to
Instructions here
http://www.mountainbikerides.co.uk/fettling/hope_hub.htm
Bearings from here or similar
http://simplybearings.co.uk/shop/p6184/SKF60012RSHC3+Sealed+Ball+Brg+12x28x8mm/product_info.html
Posted : 08/04/2009 7:49 am
Bearing play or Worn Axle.
Had the same problem with mine a while back. Replaced two bearings but it was the axle that was worn, were one of the bearings sat.
Posted : 08/04/2009 8:39 am
