Hope X2 New Pads
[Closed] Hope X2 New Pads
[#3961489]
Hi just bought some new pads for my hope x2 discs. This is the first time i have ever changed any disc brake pads and when i went to insert them they would not fit because the pot was set to my old worn out pads, do i need to bleed the brakes to make the pads fit?
Please Help and thanks in advance.
Posted : 10/05/2012 1:48 pm
No, just get a plastic tyre lever in between the pistons to push them back in before fitting the pads. Don't use metal levers as you can scratch the pistons.
Posted : 10/05/2012 1:59 pm
Better still than tyre lever - take a wooden clothes peg apart and use the two wooden wedges in opposition to gently push the pads in.
Posted : 10/05/2012 2:03 pm
clean around the pistons and apply a drop of silicone lube around them, not too much tho, and make sure you push them back in squarely. clean off any excess silicone and fit pads...
Posted : 10/05/2012 6:40 pm
Wooden spatula from the kitchen toolbox is perfect for the job of pushing pistons back in 8)
Posted : 10/05/2012 7:01 pm
