Hope x2 bore caps
[Closed] Hope x2 bore caps
[#3224216]
I'am going to change my bore caps from black ones to bling blue ?
Do I just unscrew old ones out and screw new ones in or is it a big job ie strip and re-bleed brakes
Cheers guys
Posted : 08/10/2011 11:35 am
Remove the bore cap on any brake and you'll need to refill/bleed. The X2 cap threads inwards, so you'll also have to remove the piston first. It's a very simple job if you have the correct tool.
Posted : 08/10/2011 12:51 pm
Thanks
I thought so
Posted : 08/10/2011 1:31 pm
