Do i need to use the little cup n cone washers as you do on avids, or does the caliper fit straight to the post mount on the fork or is adapter?
Posted : 05/11/2010 6:46 am
Staight to the post mount on hopes then a washered bolt through it
Posted : 05/11/2010 7:41 am
You need an adaptor for the size discs you want to use.
Bolted straight to the post mounts I think the X2 would need a 140mm disc. If you are getting them new the adaptor you request comes in the box.
Posted : 05/11/2010 10:12 am
Bolted straight to the post mount on the front it will fit a 160mm disc.
Posted : 05/11/2010 10:22 am
Ta like
Posted : 05/11/2010 10:32 am
