Hope Tech X2 - fron...
[Closed] Hope Tech X2 - front brake failure
[#4871555]
Out today for a routine pootle around my local and very muddy woods and I was literally just riding along when my front brake began to feel very spongy. I stopped and tried the lever a few times and it became progressively softer until it came back to the bar. Some fluid appeared to leak from the lower reservoir and there was no pressure on the lever. The lever piston moved but there was no resistance and the calipers did not respond. When I got home I checked the reservoir and there was still quite a lot of fluid there. I attempted to bleed but could not get the fluid to pump - the lever had no effect when depressed.
Any ideas what could be the cause?
Thanks
P
Posted : 14/02/2013 7:28 pm
Blown seal or crack or similar. Some of your fluid leaked out.
Posted : 14/02/2013 7:33 pm
There is a leak somewhere in the system. when bleeding, you probably sucked in air from the leak too.
check all the fittings.
Posted : 14/02/2013 7:57 pm
 SOAP
Sent mine to Hope on Monday back today best £44 I have spent,
New pads,pistons seals and a full service
Posted : 14/02/2013 8:05 pm
Thanks chaps
They are on their way to Hope for a service/repair
Posted : 15/02/2013 6:54 pm
Failed master cylinder piston seal....did one last week.No biggy.
Posted : 15/02/2013 7:02 pm
Be interested to know how old, sounds like master cylinder/piston seals.
Posted : 15/02/2013 7:12 pm
@Dales_rider
They are about 4 years old. Worked flawlessly with little or no maintenance until now.
Spoke with Hope today and Im happy for them to service them.
Posted : 15/02/2013 7:16 pm
oooops.
Posted : 15/02/2013 7:17 pm
Sent mine back to Hope charged me a ridiculously low amount of money and shipped it back good as new.I like the Hope men as they fixed my hub as well which I knackered for very little £$£
Posted : 15/02/2013 7:20 pm
penguinni - Member
Thanks just wondering as I have some, be interesting to find out what Hope say was the problem.
Posted : 15/02/2013 10:18 pm
They won't tell you. They''ll just come back like new.
Posted : 15/02/2013 10:36 pm
Posted : 16/02/2013 2:08 am
