Hope tech x2 advise...
[Closed] Hope tech x2 advise please
[#3181511]
Had my brakes squeaking like mad so took pads out of the rear for a check.
One pad is full and the other is really worn down, i remembered this was the case the last time i changed them.
So i checked the calipers were moving freely to discover the outermost one wasn't even moving. Finally got it to move out after holding the free one back with a screwdriver. Now i have oil squirting out around the piston that was previously stuck.
Is this just a case of replacing piston seals and will i need to get the brakes bled?
Posted : 25/09/2011 7:47 pm
new seals and bleed the brake - all straightforward - see the vids on the hope site. New pistons might be useful as well.
Or send it back to hope - they will rebuild it as new with new pads for much cheapness
Posted : 25/09/2011 7:49 pm
YGM
Posted : 25/09/2011 9:15 pm
