hope tech v2 questi...
[Closed] hope tech v2 question pls help ?
[#4258845]
can i use the hope tech v2 brakes with my shimano adapters , ive just nabbed some lovely looking brakes, but right now ive got xt calipers on adapters for bigger discs, im not sure how to progress once they arrive ?
obviously i need hope rotors, do i also need hope brake adapters too ? or can i get away with the shimano ones ?
Posted : 14/08/2012 7:22 pm
What size? The adaptors set the size rather than the caliper. If you use a 200mm adaptor with a 203 rotor, it might scrape a little on the outer edge. A washer under the caliper will sort this though.
Posted : 14/08/2012 7:28 pm
hmmm ive got a 180 on both front and rear, i could ? just grab some hope adapters after looking at how cheap they are, how good are the tech v2 brakes compared an old pair of xt ?
Posted : 14/08/2012 7:32 pm
Not ridden old xt but love my v2. 203 front, 183 rear. The Hope adaptors look nicer anyway.
Posted : 14/08/2012 7:37 pm
yeh ive just been looking on CRC
cant wait to get them, have to wait until the 24th until i can finish paying for them tho.
Posted : 14/08/2012 7:39 pm
ancient I will send you an email think i found one in your previous posts.
Thanks
Posted : 14/08/2012 7:52 pm
ive just had an email and replied. 🙂
Posted : 14/08/2012 8:00 pm
ok guys, i need to update this thread with more questions....
ive got some rock shox sid race forks, and a trek 8900 zr frame, im unsure of the correct adaptors now for the new hope brakes im going to be putting on very soon.
id like to use a 203 on the front and a 183 on the rear...
im not sure what to order from crc, do i need to the post mount is to is adaptor on the front ? im unsure about the rear too, any help is much appreciated.
many thanks in advance 🙂
Posted : 20/08/2012 4:48 pm
Bear in mind that the V2 brakes only work with the V2 rotors due to the surface area being larger than most (correct me someone if i'm wrong). Also a 203mm rotor would be a bad idea on a Sid xc fork due to the stress it would put on the fork.
If going on an xc bike would the tech x2 brakes not be a better option, or even m4's if your looking for more power?
Posted : 20/08/2012 5:12 pm
its a v2 up front and a m4 on the rear
quite happy to stick with 183 both front and rear....
all im really asking is , what adaptors do i need ?
im happy to just grab 183 front and rear.
pls help.
Posted : 20/08/2012 5:28 pm
If your SIDS are the older ones with IS mounts (two little tabs with holes in the side) you need [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=15622 ]This[/url] for a 183 disc
If they are newer ones with post mounts (two posts with a hole in the end) you need [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=13728 ]This[/url] to fit a 183 disc
I wouldn't go bigger on a Sid
Posted : 20/08/2012 5:41 pm
thanks a lot fellah, its the 2nd one 🙂
can you just help with the rear, i think i need [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=13739 ]THIS [/url] one ?
Posted : 20/08/2012 5:47 pm
Your welcome 😀 and it is...
Posted : 20/08/2012 5:50 pm
nice one, all i need to do now is find matching rotors in 183, lol
impossible !
having said that, i wonder what these are like..
[url= http://superstar.tibolts.co.uk/product_info.php?cPath=50&products_id=455&osCsid=atiooc41gknnjp8v7rcq5nqab1 ]180 mm ROTORS[/url]
Posted : 20/08/2012 5:54 pm
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=80554 ]These...[/url] 😀
Posted : 20/08/2012 5:56 pm
lol, see my edit ?
also ive spotted those but they dont do a matching m4 in the same size 🙁
Posted : 20/08/2012 6:00 pm
One of [url= http://www.chainreactioncycles.com/BasketAdd.aspx?AddToBasket=true&StockID=38125 ]These[/url] would be fine on an m4
Edit..I'd get hope rather than superstar personally, heard some horror story's about those on here
Posted : 20/08/2012 6:04 pm
ok, sorted then, and for some reason when i clicked your link, it went straight to my [ updated ] basket, lol
did you look at my edited post with the 180 rotors ??
thanks again !
Posted : 20/08/2012 6:05 pm
You can run a v2 rotor on a m4, it's the other way round you have problems due to the bigger v2 caliper, so a matching pair of v2 rotors would be fine.
See my edited post... 😆
Edit
Edit
Edit....
Posted : 20/08/2012 6:10 pm
ahh, ok , lol
thanks again, can you tell me is the black anodised that hope uses the same on ALL rotors cos they look slightly different ?
Posted : 20/08/2012 6:13 pm
I think so, I've had m4 and v2 black rotors and they looked the same.
Famous last words.....I'd get two v2 rotors personally.
Posted : 20/08/2012 6:15 pm
lol, ahhhh v2 rotor with an m4 caliper ?
were both editing like mad men, ive seen what u said now about using 2 v2 rotors, i think ill just grab two v2 rotors 183 mm in black and have done with it.
Posted : 20/08/2012 6:17 pm
Stif have 10% off v2 rotors too
Posted : 20/08/2012 6:19 pm
Yep, it'll be fine..
Posted : 20/08/2012 6:20 pm
wolly, nice one, ill grab 2 from there 🙂
gonna grab [url= http://www.stif.co.uk/mtb/product/hope-saw-floating-140-160-180-183mm-disc-rotor/9086 ]two of these in 183 [/url]
Posted : 20/08/2012 6:21 pm
Noooooo!!!! They're m4 m2 ones, They'll foul the v2 calliper.....
Get the v2 disc as they have a deeper braking surface for the bigger v2 calliper
Posted : 20/08/2012 6:30 pm
lol, ok, thanks for helping !
[url= http://www.stif.co.uk/mtb/product/hope-v2-floating-183mm-disc-rotor/10677 ]better ? [/url]
Posted : 20/08/2012 6:33 pm
Perfect... 🙂
Posted : 20/08/2012 6:43 pm
right then, job done, finally, thank you for your patience 🙂
Posted : 20/08/2012 6:44 pm
