I've got a couple sets of hope tech 2 levers and I've noticed on the new ones I've fitted that the rear one has a small amount of brake fluid weeping from the two breather holes .its only a tad but the other lever doesn't do it nore do my other set on my other bike. The lever feel solid with no air or sponginess .I followed the bleeding instruction when I changed the hose and filled the resovoir to the brim and rolled the diaphragm on before fitting the cap etc.
Is this likely to be some excess fluid that might be on top of the underside diaphragm between the cap.this is the side I never removed by the way .
Pinched diaphram when tightening the cap/cover most likely from memory
